Stuck manifold plug, HELP
Old Sep 6, 2011 | 10:35 PM
Scotty76's Avatar
Scotty76
Default Stuck manifold plug, HELP
Anyone have a good solution to remove a stuck brass plug in my intake manifold?
I have drilled through it and now have an easy out on it backed by a milwaukee hammer drill. I hit the trigger the lights dim and it still won't budge.
I have applied some heat and PB Blaster. Afraid to heat to much as I am inches from the gas line and carb.
Ready for a grenade at this point!!
Old Sep 7, 2011 | 01:08 AM
Vette5.5's Avatar
Vette5.5
Kinda confused why a Milwaukee hammer drills involved. Since you've already punched a hole, a slide hammer with a hook's probably your best best. A little torch heat heat's probably good idea too. Set up an air mover when using a torch. You can get mineral packed heat shield sheets you can stick between parts. Mines a Pace Machinery Group Flame Gard. You can put a flaming torch tip right to it.
Old Sep 7, 2011 | 11:17 AM
bashcraft's Avatar
bashcraft
I'm kinda confused as to how you're going to unscrew a plug with a slide hammer.
Anyway, forget the torch if you're any where near gas. A buddy once burned down his garage along with multiple cars trying this.
Can you just put a wrench on the ez-out? How big is the ez-out?
Old Sep 7, 2011 | 12:01 PM
Vette5.5's Avatar
Vette5.5
Yup, my mistake, as somehow mistook the original question as a freeze plug. Also agree on the fire safety thing too, as know guys who've burned up projects as well. Sometimes a torch is the only option though, and should be fine with air circulating and proper insulating proceedures.
Old Sep 7, 2011 | 01:16 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
well if you have already drilled through it i guess shavings arent much of a concern at this point. i guess you could just keep drilling it bigger and then use a drift and collapse it in on itself. and then vacuum everything out you can.
Old Sep 7, 2011 | 01:23 PM
Ganey's Avatar
Ganey
On stuck brass plug, I used a breaker bar & applied force slowly to try not to break the al. intake & it worked.
Old Sep 7, 2011 | 02:11 PM
wcsinx's Avatar
wcsinx
My thoughts as well.
But I'll also say a hammer drill really isn't going to have the torque to twist out a corrosion-frozen plug. If you can still get a socket on it, try an impact wrench. The vibration and torque of a good impact can break stuff like that loose.
That failing, get out the drill bits.
Old Sep 7, 2011 | 02:25 PM
Vette5.5's Avatar
Vette5.5
Yea, suppose you could just keep drilling it larger until there's nothing left. As for the metal shavings, some grease on the drill bit, and a shop vac right on it will certainly help.
Old Sep 7, 2011 | 04:47 PM
wcsinx's Avatar
wcsinx
Meh, it's the cooling circuit not oil. Certainly clean & vacuum out what you can, but a few brass drill shavings won't really hurt anything.
Old Sep 9, 2011 | 08:29 PM
Scotty76's Avatar
Scotty76
Default Success!!
5 days and here is the end result:
It's out!!
In the end, I put a wrench on the easy-out and a pipe wrench on the raised portion of the plug. Took a little elbow grease but it came out.
Used a rag to pull out the shavings.
Thanks for the feedback fellas!!
To Stuck manifold plug, HELP
