rear defroster wire location
Old Sep 7, 2011 | 03:30 AM
silveranniversary's Avatar
silveranniversary
4th Gear
Default rear defroster wire location
I am redoing my interior and already installed the carpet. I can't seem to locate the wire for the rear defroster on the rear glass. Where does it come from? I tried following the wire from the switch but it goes up behind the dash. Where should I be looking? Thanks in advance
Old Sep 7, 2011 | 08:10 AM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
You'll have to remove the halo panels to see where it plugs into the glass. I'm not sure where it goes from the switch but I would guess under the door sills and up behind the carpet behind the seats and then behind the halo panels. I believe it splits and each side of the glass has a plug in but don't quote me on it. It's been a while since I had the halo panels off of my 82.
