Leaf Spring Help needed Bolts won't seat
Old May 1, 2002 | 12:06 AM
eddadams's Avatar
eddadams
Default Leaf Spring Help needed Bolts won't seat
I just installed a new Vette Brakes 9 Leaf spring on my 75 and the two forward bolts that go into the differential cover will not seat completely. The two rear bolts that go through the tabs on the differential cover are fine. These are the original bolts that were in place with the old spring. All four are the same length. I have cleaned the treads with a wire brush and tried all four bolts in the forward two holes with no success. I have tried tightening them with the no load on the spring and with the spring loaded. I have torqued all four to 70lbs. Still no luck. Has any one had a similar problem? :confused:
Old May 1, 2002 | 01:51 AM
Steve Straus's Avatar
Steve Straus
Default Re: Leaf Spring Help needed Bolts won't seat (eddadams)
When I installed my new spring the cushions between the springs made the leaf about 1/2 an inch thicker. I ended up using slightly longer bolts. After the cushions compress a little I'm going to check them out. Be careful with the forward holes, they are blind holes and you don't want the bolt bottoming out in the hole.
Make sure you have the weight on the wheels when you're torquing the bolts down, you can break the rear cover if you're not careful.
Old May 1, 2002 | 02:11 AM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
When I installed my spring, I put a jack under it, raised it up in place, and then started all four bolts. When you say they "won't seat", do you mean that they aren't catching any threads? Or that they bottom out before reaching the spring plate? There is a small protrusion on top of the spring that MUST go into a matching hole on the bottom of the differential. I used the jack to hold up the spring while I manuevered it around to get it in place. Can be a major pain. Just have patience.
Old May 1, 2002 | 03:24 AM
Cajun99's Avatar
Cajun99
Default Re: Leaf Spring Help needed Bolts won't seat (sharklover)
When I installed my spring, I put a jack under it, raised it up in place, and then started all four bolts. There is a small protrusion on top of the spring that MUST go into a matching hole on the bottom of the differential. I used the jack to hold up the spring while I manuevered it around to get it in place. Can be a major pain. Just have patience.
When I replaced mine I too had a jack under the center to keep the "locator" pin in the hole (that spring's heavy!). But because of the arch and new plastic pads between the leafs I had the same problem with the bolts being too short for the front holes like some of the guys above. Had to go to a bolt place and buy slightly longer, and much stronger, bolts. Problem then was still the arch and the spring mounting plate that wouldn't sit flat enough to get the new bolts started. Aggravating!!
Went and got a pal and we ended up placing a floor jack under each spring end and together we jacked up the ends until the spring was compressed and flat (kept the original jack under the center to keep it in place). Now the spring mount plate was flush and everything went right together. Moderately tightened everything up, put everything else back together and torqued the center bolts with the car on the ground and retorqued after several miles. Have had no problems since but it was a good learning experience.
Old May 1, 2002 | 05:12 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Leaf Spring Help needed Bolts won't seat (Cajun75)
I know nothing of the VB spring, but I would check the thickness of your original against the replacement. The front holes are blind. If the bolts are too long, and you keep torquing them, you'll break through the bottom of the diff case, and end up with a rear end gear oil leak. You may need to buy shorter bolts. Also, never torque the 4 spring bolts until you have weight on the spring. That's a sure fire way to break an ear of the case. Hope this helps. Chuck
Old May 1, 2002 | 09:11 AM
eddadams's Avatar
eddadams
Default Re: Leaf Spring Help needed Bolts won't seat (Chuck Gongloff)
I too used a jack to hold the spring and the plate in place as I tightened the 4 bolts. The problem is the forward two are bottoming out before tightening flat against the plate. So I guess I will have to get short bolts. I understand about doing the final torque with the weight on the tires. When you put the weight on the tires the spring flattens out and you can then tighten the bolts further. Thanks for you suggestions
Old May 1, 2002 | 11:09 AM
ylose's Avatar
ylose
I just replaced mine 3 weeks ago...VB 7 leaf..my old one was beyond flat.
I braced up each end, then was able to line up the locator and tighten my bolts...as said above...if anything, get a slightly shorter bolt, or you'll bust through the case... :nono: only hand tighten when on the jacks...
once you lower the car and load is set....then slid under and finish the tightening... :cheers:
Old May 1, 2002 | 12:17 PM
eddadams's Avatar
eddadams
Default Re: Leaf Spring Help needed Bolts won't seat (ylose)
Well I found the problem. My old spring is 9 leaf as is the new one but the old one has an extra metal strip about 5 inches long on the bottom side of the spring. The strip is not a full leaf. It only fits under the mounting plate. So there is the extra thickness. I called Vette Brakes and they said their spring is an exact fit. He said someone must have changed my spring and put in longer bolts. The car has only 50,000 miles so I highly doubt that the spring was switched and longer bolts added. So I have a few options, 1- cut the bolts to make them shorter, 2 - get new shorter bolts, 3 - take the plate off the old spring and put it on the new one. I think I am going to try cutting the bolts first. If that doesn't work I will get new bolts. I will keep the old spring intact in case I ever one it for restoration.
Old May 1, 2002 | 02:07 PM
Captain Morgan
Cruise-In V Veteran
:bs on someone switching it. My 79 has the exact same spring as your original. And I know for a fact that it's the original. The guy at VB doesn't know what he's talking about. Call and ask to talk to someone else. Or you could just get shorter bolts. But either way, I would still let VB know.
Old May 1, 2002 | 02:16 PM
mayberg's Avatar
mayberg
So I have a few options......2 - get new shorter bolts.....If that doesn't work I will get new bolts.
The bolts on mine are 9/16 x 12 threads, and for the length I needed they were not easy to find. You may have to root around the used Corvette suppliers to get the proper bolt size.
Old May 1, 2002 | 02:25 PM
R. Bruno's Avatar
R. Bruno
I had the same problem with a 7 leaf. The replacement was slightly thinner than the old 7 leaf which I am sure was original. So much for the exact fit theory!! I just threw a lock washer between the bolt head and the spring plate and that was enough to take up the slack. I know it is slightly Bubba-esk but effective and I have had no problems.
Old May 1, 2002 | 02:51 PM
79 vette's Avatar
79 vette
Default Re: Leaf Spring Help needed Bolts won't seat (R. Bruno)
I replaced my 9 leaf a couple of months ago with a 9 leaf from mid-america had no problems putting it in.I also bought a kit from mid-america with it also it came with a new bottom plate and new bolts forgot how much it was but wasn`t too much also when putting in the spring I placed a jack under the center of the spring caught the 4 bolts then worked on the ends :seeya
Old May 1, 2002 | 06:33 PM
mayberg's Avatar
mayberg
I had the same problem with a 7 leaf. The replacement was slightly thinner than the old 7 leaf which I am sure was original....I just threw a lock washer between the bolt head and the spring plate and that was enough to take up the slack.
Bruno, there's supposed to be a lockwasher for all the bolts!
To Leaf Spring Help needed Bolts won't seat
