Okay.. you line up the 32 (or whatever) on the balancer with the zero on the scale. that makes sense. I think I'll go ahead and order the tape.
Thanks guys
You'll have to know to buy the correct tape and if you know the diameter , then you'll have the circumference,divide the circumference by 10 and you will have a 36 degree mark.
For instance if you have a 6 3/4 , and you measure down 2.1" from the mark on your dampener you'll be at 36
Tapes are great once they're on good but sometimes its a process to get them on and to stick and your only going to use 1 slash mark on the whole tape.
I just bought the tape posted by Scott, I hope its the right one. I can't
measure the diameter with the belts & pulleys in the way, but I can get the circumference if I need to.
Here's a HP 8 1/4" with long paint mark at 34 and the 2 little marks at 18 either side of TDC.
36 is simple to figure,other marks I have to ask my kid to figure for me.
Note that timing tape is significantly less useful unless the TDC indication is very accurate - not always the case. I'd highly suggest verifying this before sticking on the tape...
and once you verify TDC on the balancer,put a paint mark on the pulley that lines up with the TDC on the balancer,if you ever suspect the balancer of slipping you can check at a glance.
So the mark on the balancer may not be TDC? Is the best way to check a screwdriver in spark plug hole #1?
The TDC markings include the pointer on the front cover and the balancer...either one can be screwy
Noooooo screwdrivers in spark plug holes You'll want a piston stop as below - someone nearby may have one. Ideally, you'll also want an easy way to manually turn over the engine; I like the tool that ratchets onto the flexplate/flywheel.
Here's my math on paint marking the balancer if anyone is interested in marking their balancer.
I hope its right.
small balancer ( L48 )
6.75x3.14=21.195/360=.0588x32degrees=1.88" down from TDC
""""""""""""""""""""""""""""""""""""34de grees=1.99"
""""""""""""""""""""""""""""""""""""36de grees=2.11"
large balancer ( L82 )
8.25x3.14=25.905/360=.0719x32degrees=2.30" down from TDC
""""""""""""""""""""""""""""""""""""34de grees=2.44"
"""""""""""""""""""""""""""""""""""" 36 degrees=2.59"
(using a tape and actually measuring the circumference is best)
The link I put in my post was to a timing tape for a 6 3/4" dampener, which is what SHOULD be on your motor if it's an L48.
I installed mine when I had all the front accessories off converting to a serpentine belt system, so it was easy to clean the surface properly and install nice and straight. I think it's doable to install the tape with all the accessories still on, but it'll be a PITA. Make sure you clean the surface well.
Yes, I have the l48, so that should be the correct one.
That's a handy looking tool Billa. I may bite the bullet and get one, though I'm sure I'll only use it the one time. I've turned the motor before with a ratchet on the front pully, so that should not be a problem.
Thanks again guys!
Once you go through the timing exercise and see the difference it makes, your buddies will be all over you to help with theirs...so that little tool will find a lot of use
