heater... arrghh...
Old Sep 11, 2011 | 09:23 AM
jman1's Avatar
jman1
Default heater... arrghh...
ok... i replaced all the vacuum lines (thanks to all the info here!) and got the defrosters and vents all working.... the ac isnt hooked up but thats ok..... but the heater is blowing warm air at best.... am i missing something? i looked for a shut off and didnt see one...it got plenty hot in the car and on the passenger side this summer ....
Old Sep 11, 2011 | 09:58 AM
...Roger...'s Avatar
...Roger...
Is the hot-cold mix door closing all the way ?
Old Sep 17, 2011 | 03:10 PM
jman1's Avatar
jman1
theres a switch on top of the heater box where the cable attatches... it looks like it has a little plunger on it and as you slide the lever from hot to cold it catches that plunger about half way and pushes it in....... seems like its working correctly.. could that plunger be the issue? should it be coming out more?... and could it be as simple as no thermostat?
Old Sep 17, 2011 | 03:33 PM
myk7's Avatar
myk7
I imagine the cable just needs adjusting, not sure what the plunger is. Take the cable off and check the door travel, all the way one way is closed and you should get no to very little heat, the other way is full heat... just make sure the cable closes the door tight when the setting is set to cold.
Old Sep 17, 2011 | 06:09 PM
jman1's Avatar
jman1
is there any way to see the door opening and closing? i took off the dash on the passenger side but it looks like is buried from there...
Old Sep 17, 2011 | 06:33 PM
myk7's Avatar
myk7
I'm not sure.. on my c4 you can take a module out of the casing in the engine compartment and see the door working, maybe the same on a c3? You can tell a lot just by moving the door arm with your hand.. if it "feels" right, it probably is. Just check that the cable is moving it all the way shut.
Old Sep 17, 2011 | 07:01 PM
jman1's Avatar
jman1
i was letting the car warm up and after about 10 minutes is was blowing hot! i went for a ride and it cooled right down. i got a 180 thermostat... im gonna try that tomorrow... i dont see a way to check the door but there is a vacuum plunger on the top of the heater box.. if the thermostat dont cure the problem... thats next on the list......
Old Sep 18, 2011 | 04:04 PM
jman1's Avatar
jman1
ok.. theres a little vacuum controled plunger on top of the heater box.... i have searched for it and cant find one.. i think its leaking and causing the no heat issue.... anyone.. whats it called? i searched the site and the major vette parts sites and cant find one....
Old Sep 18, 2011 | 04:07 PM
myk7's Avatar
myk7
What year is your car? Maybe flushing the heater core would help.
Old Sep 18, 2011 | 04:29 PM
jman1's Avatar
jman1
its a 77... its this part... with the spring on it... its leaking and not closing the door ... i pull out on that plunger and the heat works perfect....
Old Sep 18, 2011 | 04:51 PM
...Roger...
That valve operates the hot water shut off valve under the hood.
Old Sep 18, 2011 | 04:53 PM
...Roger...
Try spraying some silicone inside and then push it in and out a few times.
Old Sep 18, 2011 | 04:58 PM
thegazman's Avatar
thegazman
Default thegazman
That little plunger is the valve that allows vacuum to open you heat control valve inside the engine compartment. When you push the temperature lever to the coldest position on your heater/Air conditioner control on the dash the cable closes the heater door and tab on top pushes in on the spring loaded plunger shutting off the hot water from the engine.
To heater... arrghh...
