power window problem
Old Sep 11, 2011 | 09:46 PM
79 vette 13's Avatar
79 vette 13
Default power window problem
i have a question im hopeing someone could help me with, my driver side window dosent want to go down, the passenger one works fine though, also when i hit the switch the power gauge does move so it is drawing power. just wondering if theres a common prob or should i just tear apart the door and replace the motor? its a 1979 L82. thanks for the help in advance
Old Sep 11, 2011 | 10:18 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It could be the regulator locked up. You should pull the door panel and see what is going on.
Willcox
Old Sep 17, 2011 | 08:38 PM
79 vette 13
well i finally got around to taking the door panel off and i can hear a click in the motor when i hit the switch, so im thinking that theres power still getting there and the motor is bad and needs to be replaced ? or is there another possible problem?
To power window problem
