Power Mirrors
Old Sep 13, 2011 | 01:35 PM
classicguy's Avatar
classicguy
Default Power Mirrors
Yesterday I decided to change out my power window switch since it was obvious that someone had put in switches from another gm car and also decide to change the joy stick for the power mirrors to the correct alignment ( up was down and out was in they worked it was just annoying) found that the joy stick was correctly aligned can only go in one way but the wire for some reason were cut and re wired in my haste I took off the electrical tape it sparked now I have no power. So question what fuse controls the power mirrors not in my assembly manual or repair manual. Also the power window switch insert on consol were butchered so that was also a bust.
Old Sep 13, 2011 | 03:03 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Owner's manual will show the PM fuse. If memory serves, there is also a relay for the mirrors.
Old Sep 13, 2011 | 04:54 PM
...Roger...'s Avatar
...Roger...
Radio fuse controls the mirrors.
Old Sep 14, 2011 | 02:21 PM
classicguy's Avatar
classicguy
Well don’t have an owner’s manual and the radio is working. Are mirrors always hot or do you have the ignition for them to work? I did try with on
Old Sep 14, 2011 | 03:04 PM
...Roger...
From the factory the mirrors are hot at the same the radio is,acc or on position.
Sounds like bubba might have done some rewiring so the mirror power could come from anywhere.
Did you have the ignition key turned on when you sparked the wires ?
Old Sep 20, 2011 | 05:46 PM
classicguy's Avatar
classicguy
key was on because i was also checking window switches. I pulled every fuse and check them with a meter. They were all good so problem is somewhere else. I need to find a schematic or find out where the power comes from
Old Sep 20, 2011 | 06:21 PM
...Roger...
Check the brown/white stripe at the switch for power.
To Power Mirrors
