Drivers mirror fix ?
Old Sep 13, 2011 | 03:55 PM
boltnut's Avatar
boltnut
Default Drivers mirror fix ?
Is there a way to get more life out of my OE drivers side mirror? It flops down when I hit a big bump or hit 100 on the freeway. I just want to stiffen it up a little .......
Old Sep 13, 2011 | 04:32 PM
fcservak's Avatar
fcservak
Cruising
Default Fix it yourself
I used a little rubber cement on the ball. Flop the mirror all the way up, down, left and right and using a small paint brush apply the rubber cement to the part of the ball that will be in the socket when the mirror head is in the driving position. After applying the glue, move the head around a little to distribute the glue, let it dry and wipe off the excess on the exposed part of the ball. It seemed to "fix" mine (no pun intended).
Old Sep 13, 2011 | 04:58 PM
Rally68's Avatar
Rally68
Get a spring-loaded center punch (Harbor Freight sells one for around $3) and use it to dimple the ball. Move the mirror around to expose as much of the ball as possible while making a couple dozen evenly distributed punches. 3 years since I did mine and it's still like new.
Old Sep 13, 2011 | 05:25 PM
birdsmith's Avatar
birdsmith
To adjust the tension spring inside the mirror head, you can remove the mirror glass by soaking the unit in lacquer thinner for a half hour or so. This loosens the adhesive so you can easily pry the glass loose. You can then tighten up the spring inside the mirror head. After that you can reinstall the glass with a bead of RTV.
Old Sep 13, 2011 | 05:32 PM
Wrencher's Avatar
Wrencher
There is a really great paper on this somewhere, probably in the FAQ area. Basically I used a gasoline soak overnight (the glass fell out), then used some really thin shim stock (with a slot cut in it) wedged between the rivet and the spring steel (both sides) that holds tension on the mirror pivot ball. After that, JB weld to hold the shim, silicone to re-glue the glass and now both sides are real tight!
Hans
boltnut's Avatar
boltnut
Great ideas guys.....I knew I would get better than " just buy a new one " !
Old Sep 13, 2011 | 10:39 PM
Mashman's Avatar
Mashman
If you want to fix it the correct way, you need to take the glass off first. The you can see what the issue is. If it's an original, it will have rivets, and will require shims to keep it tight. If it's an aftermarket mirror, it will have screws, and a plastic bushing that has torn - go to lowes and get some plastic washers and you will be good to go.
Old Sep 14, 2011 | 09:23 AM
63split63's Avatar
63split63
I replaced the plastic washer in mine with a flat water tap washer ( the black internal seal that was used inside older sink faucets ). They are cheap and you can buy them at any hardware store .
Bill
Old Sep 14, 2011 | 11:54 AM
08vycpe's Avatar
08vycpe
I have a .pdf with pictures that someone posted a long time ago to fix this common issue. Send my your email in a PM and I will attach the .pdf.
The thing I did differently was to soak the mirror is lacquer thinner instead of gasoline. Safer and the glass just fell off after 5 hours of soaking.
To Drivers mirror fix ?
