82 Vette-Ignition Switch
Old Sep 13, 2011 | 07:54 PM
biaggio's Avatar
biaggio
Default 82 Vette-Ignition Switch
Hi,
82 vette-How difficult is it to change the ignition switch(not where the key goes)? Thanks
Old Sep 13, 2011 | 08:48 PM
terry82's Avatar
terry82
could you explain your problem?
Old Sep 13, 2011 | 09:06 PM
Jim Shea's Avatar
Jim Shea
I am not saying that your T&T column has to be removed from the car to replace the ignition switch, but overall it will be a lot easier if you do.
Here are complete instructions.
http://jimshea.corvettefaq.com/wp-co...ev09ja2010.pdf
Once you have followed these instructions and the column is out of the car, you can skip the info on removing the turn signal switch, etc. Just go directly to removing and adjusting the ignition switch.
http://jimshea.corvettefaq.com/wp-co...ev21mr2009.pdf
To 82 Vette-Ignition Switch
