i went to take the POS battery cable off my starter....it was a little stuck due to age.....i heard a nice loud CRACK and the stud seems a little loose.
i am assuming trying to start the car would be a mistake and i need to pull that solenoid....what do you think i broke ?
on the positive side of things i DID get the motor mount on !
Thanks. I feel better. Never broke one before. Glad I had the battery disconnected like a good boy. I was planning on upgrading to a mini starter.....maybe sooner than later.
That is an understatement, I do a lot of electrical work and sometimes I work with the battery connected when I shouldn't BUT I never ever work at the starter with the battery connected.Thumbs up to to you it only takes 30 seconds to remove the neg cable,be safe.
