Carter replacement fuel pump, return opening size
Old Sep 16, 2011 | 10:01 AM
dembo's Avatar
dembo
Default Carter replacement fuel pump, return opening size
Hey,
I received my replacement carter pump today (summit couldn't ship a Delco one to Belgium ).
Does this return opening look correct? It's more like a nozzle & almost 2/3 of the full opening is blocked.
Air does come out if you blow into the inlet with the pressure outlet blocked.
Thanks,
Nick
Old Sep 18, 2011 | 01:14 PM
dembo's Avatar
dembo
No one? Guess I'll drill it out.
Nick
Old Sep 18, 2011 | 01:15 PM
Mike Ward's Avatar
Mike Ward
Looks correct to me.
Old Sep 18, 2011 | 02:05 PM
...Roger...'s Avatar
...Roger...
Nick
I wouldn't drill it out , you might have "too" much fuel returning to the tank. Just a guess but maybe Carter put the orifice where you can see it instead of inside the pump as Delco did. I have a pic of the Delco I'll see if I can find for you.
Old Sep 18, 2011 | 02:11 PM
7t9l82's Avatar
7t9l82
it is fine, do not drill
Old Sep 18, 2011 | 02:17 PM
...Roger...
Nick,here is the way Delco makes the orifice inside the pump,its aprox .070. I'm no engineer but I don't think even if your pump has 2 orifices ,1 inside and 1 out it would cause a problem. Engineers-is this correct ?
Old Sep 18, 2011 | 02:21 PM
Mike Ward's Avatar
Mike Ward
Correct.
Old Sep 18, 2011 | 02:24 PM
dembo's Avatar
dembo
Thanks alot guys, glad I asked before drilling
Regards,
Nick
To Carter replacement fuel pump, return opening size
