Right when things start coming togather... Glad Dad was outside before I started drivin. Its leeking on the passenger side of the tank. Im thinking its the flex hose?? What kind of project is this going to be? thanks :crazy:
EDIT: i cant see the exact source of the leek, just leeking down the right side....
Drain the tank.... Remove the sending unit.
Drop the spare, as well as the spare tire carrier.
There will be a couple of bolts holding the tanks straps in place - take them off. Then there is a crossmember with a bolt on either side.
Not sure about a 77, but I changed my flex hose with the tank in place. The hardest part was connecting the tank end by feel. Still it was not to bad. :chevy
