Charcoal canister --PART 2
Old May 1, 2002 | 10:52 PM
shoptek's Avatar
shoptek
Default Charcoal canister --PART 2
I emptied the old charcoal granules from the canister, soaked it in degreaser, washed and blew it dry.
I went to the local pet shop and picked up some granulated charcoal (used in aquariums), refiled it, new fiber filter and.......IT SEAMS TO WORK! I used to have a potent raw gasoline smell after a 10 min. ride. Tonight it smelled spring time fresh!! :yesnod:
Call me Bubba, but I needed to save the $50 bucks for better things than a plastic can with charcoal in it.
Old May 1, 2002 | 11:39 PM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: Charcoal canister --PART 2 (shoptek)
Would that 50 bucks be going into Yoders pocket this weekend? :D I'd say that's a good repair job, not a bubba job....unless you put it all together with duct-tape :jester
Old May 2, 2002 | 12:06 AM
shoptek's Avatar
shoptek
Default Re: Charcoal canister --PART 2 (C3 Shark Tank)
Scott,
You should be a mind reader :D At least $50 dollars. I downloaded their menu, and have all meals and desserts already pick out! :jester :blueangel:
Old May 2, 2002 | 11:59 AM
Fleetwood's Avatar
Fleetwood
Thats exactly what I intend to do to mine,I don't see anything wrong with that method.
Old May 2, 2002 | 12:26 PM
73-454's Avatar
73-454
shoptek
Hats off to you, when I started to take the vette apart with the thought of replacing the parts with new or rebuilt after a second look it is amazing what one can do with cleaning and oiling or painting the parts, You save a ton of money and the parts always fit. If my canister needs replacing I will do the same.
Old May 2, 2002 | 02:11 PM
bigvette1's Avatar
bigvette1
Hell of an idea for refilling the cannister. :yesnod:
Old May 2, 2002 | 02:43 PM
73 LS-4's Avatar
73 LS-4
Good job :D , always wondered if that would work.
:cheers:
Pat Kunz
To Charcoal canister --PART 2
