Edelbrock 850 problem
Old Sep 18, 2011 | 10:49 PM
81cali's Avatar
81cali
Default Edelbrock 850 problem
My car sat for about a year until recently I decided to dust it off and revive it again.
I sprayed some starting fluid into the carb and started right up. Problem is, it doesn't stay running and I found out that the secondary just keeps on "pouring" gas even when the motor is not running. It will continue to this for about a good 2 minutes.
Now that it's flooded it won't start and the minute I step on the accelerator pedal, it will do the same thing again.
Please help!!!!!
Old Sep 19, 2011 | 01:02 PM
MelWff's Avatar
MelWff
You have dirt in the need and seat assembly or a float problem. Take the carb apart and clean it and check the float.
Old Sep 19, 2011 | 01:25 PM
81cali's Avatar
81cali
Thank you sir. My son did say that the float might be sticking.
Again, thanks for your assistance.
Old Sep 19, 2011 | 04:19 PM
MelWff's Avatar
MelWff
after you fix the carb problem it may be a good idea to change the oil which has been dilluted by all the gasoline.
Old Sep 19, 2011 | 11:08 PM
81cali's Avatar
81cali
Will do just that, thanks!!!!!!
To Edelbrock 850 problem
