Battery/Choke Light stuck on
Old Sep 19, 2011 | 10:48 PM
Stooney's Avatar
Stooney
Default Battery/Choke Light stuck on
**SOLVED**
My gauge cluster (excluding fuel gauge) hasn't been working since I got the car. Today I decided to open it up and check it out. I made sure the nuts on the PCB were nice and tight and noticed some of the copper pin things where the big plug goes were bend out of shape, so I straightened as best I could and put it all back together.
Ever since that, the car won't start and my battery/choke light is stuck on (without keys in ignition). The lights turn off when I try to start the car (but get nothing).
Any ideas? All fuses are fine. Car was running fine just 30 minutes before I did this.
Old Sep 19, 2011 | 10:53 PM
SIXFOOTER's Avatar
SIXFOOTER
Make sure you got the connector plugged back in correctly
Old Sep 19, 2011 | 11:26 PM
Stooney's Avatar
Stooney
So after some wiggling, and...wait for it...putting my car in park (herp derp)...the lights are off and everything is working fine. Even got a couple gauges to start moving (accuracy unknown).
I'ts one of those days.
To Battery/Choke Light stuck on
