ZZ4 valve cover clearance......
Old May 2, 2002 | 01:02 AM
Corvette0096's Avatar
Corvette0096
Default ZZ4 valve cover clearance......
I have a zz4 and i just bought some pro magnum roller rockers. Will i have a clearance problem?
Old May 2, 2002 | 01:05 AM
CDaniel525's Avatar
CDaniel525
Default Re: ZZ4 valve cover clearance...... (corvette0096)
depends on the ratio....i have zz4 and 1.6 roller rockers. no problems here....
if you have a problem, you can takethe cheap route, or the pretty route.
Cheap: use 2 gaskets...no one will even be able to tell.
Pretty: Gm sells a centerbolt to standard style conversion kit so you can use normal valve covers, and from there you can get a set of tall covers, and even the conversion kit will probably raise it enough and you can find a nice set of regular covers.
but like i said, I have no problems
Old May 2, 2002 | 09:25 AM
Corvette0096
Default Re: ZZ4 valve cover clearance...... (74VETTE)
What rockers are you running? I have read that the rockers the come with the GM hot cam kit will fit with no problem. Taller covers are out of the question, They will hit my Super ram runners. One more thing is that 306hp at the rear wheels? 1.5's is what i have.
[Modified by corvette0096, 5:26 AM 5/2/2002]
Old May 2, 2002 | 04:23 PM
BeaterShark's Avatar
BeaterShark
I don't know what the ZZ4 valve covers look like, but I am running the pro magnum rockers with .589" lift under '89 L98 Firebird valve covers. I had to use two gaskets (I RTV'ed them together) and I had to cut out the upper (as it sits on the head) brace inside the VC, but it works fine with no leaks.
Old May 2, 2002 | 11:15 PM
CDaniel525's Avatar
CDaniel525
yea corvette0096, thats 306HP at the rear wheels. I dont think youll have a problem with 1.5: roller rockers.....its when you step up to a higher ratio you have problems I think.
Old May 3, 2002 | 02:22 AM
VetteNut72's Avatar
VetteNut72
The GM 1.6 Roller Rockers will fit under the ZZ4 valve covers with no problem. A friend of mine with centerbolt heads and Crane Gold rockers had to modify the centerbolt valve covers to get the shaft which supports the bolt to fit between adjacent rockers. The GM rockers are tapered and not as wide and the valve cover bolt shafts fit between the rockers just fine.
To ZZ4 valve cover clearance......
