Caliper Recommendations
Old Sep 24, 2011 | 04:22 PM
Hef's Avatar
Hef
Default Caliper Recommendations
Looking for Caliper manufacturer/reseller recommendations for my C3.
Have looked at Ecklers (89.00), corvettes of Houston (70.00) Vette Brakes and Products (89.00) Autozone (89.00)
Recommendations welcome!
Thanks,
Hef
Old Sep 24, 2011 | 04:56 PM
'75's Avatar
'75
I don't know anything about them, but Advance Auto has them for $64 with $40 core charge. There is a thread on here somewere with online discount codes for Advance also.
http://forums.corvetteforum.com/c3-g...pon-codes.html
Old Sep 24, 2011 | 04:59 PM
Ganey's Avatar
Ganey
The ones from Auto Zone are fine. If you have SS, you can rebuild w/ VBP O-Ring kits or stock kits.
Old Sep 25, 2011 | 08:25 AM
Hef's Avatar
Hef
Yea I just tried rebuilding and for some reason its still leaking.
The pistions have alot of corrosion, and I noticed a very tiny "cut" or notch in the SS sleeve right near the top. Not sure if that is casuing the leak?
Its also a major pain (for me anyway) to get the dust boots seated evenly. I bent a couple in the process.
Hef
Old Sep 25, 2011 | 08:54 AM
GUSTO14's Avatar
GUSTO14
Hef
Hef, when you install the dust boots, it's always good to use a large socket to do this job. It makes installing them evenly much easier and reduces the chance of damaging the boots.
I would also put in a plug for Vansteel when it comes to calipers and suspension parts. They do a lot of their own R&D now and have picked up where many of the venders left off in developing the C2 - C3 suspension. Great folks to deal with and their customer service is outstanding. If you need to talk to an expert you can with them, a service that is becoming much harder to achieve with some other venders.
http://www.vansteel.com/
Good luck... GUSTO
Old Sep 25, 2011 | 09:34 AM
Ganey's Avatar
Ganey
The pistions have alot of corrosion, ...
Hef
Sounds like you need new pistons.
The VBP O-Ring kits have new pistons & the O-Ring/piston goes right in quickly.
PS If you are careful removing the old seals, it's possible to reuse if you bend a new one too badly doing it fast.
Old Sep 25, 2011 | 12:31 PM
Hef's Avatar
Hef
Good luck... GUSTO
Hi Gusto,
Yea I did use a PVC pipe fitting that lined u with the metal ring of the boot, but it would bend up at one spot.
If a caliper leaks, its not the dust boot, it has to be leaking past the lip seal correct?
Old Sep 25, 2011 | 12:47 PM
GUSTO14's Avatar
GUSTO14
That is correct...
GUSTO
Old Sep 25, 2011 | 01:54 PM
Hef's Avatar
Hef
That is correct...
GUSTO
Ok - so how would the piston cause the leak - the corrosion on the piston is above where the lip seal engages the sleeve .
Thanks,
Hef
Old Sep 25, 2011 | 02:01 PM
terry82's Avatar
terry82
i bought mine from advance auto.when you have a problem they will have one in stock or the next day .no shipping or waiting two or three days.paying more may not get you better brakes.
Old Sep 25, 2011 | 02:07 PM
GUSTO14's Avatar
GUSTO14
Thanks,
Hef
Earlier you mentioned a "very tiny "cut" or notch in the SS sleeve right near the top", that's certainly a possibility. It's also possible that the seal was damaged when you installed it or that the fluid is leaking around the seal on the piston side if there was corrosion in the seal groove.
Did you use an original style lip seal or an "O-ring" seal? (I see you answered that above...) The O-ring seals are more tolerant of excess rotor run-out which often occurs when chancing to new rotors as well.
Front or rear?
Here's a terrific deal on a pair of front calipers from a great Forum member...
http://forums.corvetteforum.com/c3-p...-calipers.html
Good luck... GUSTO
Old Sep 25, 2011 | 02:44 PM
Hef's Avatar
Hef
Thanks Gusto.
Maybe I will pull out that caliper and give it another look.
Hey I see your picture is of a V-22 Osprey. Very cool.
Were you in the marines?
Hef
Old Sep 25, 2011 | 06:28 PM
GUSTO14's Avatar
GUSTO14
Thanks Gusto.
Hef
31 years and almost never a dull moment!!
GUSTO
Old Sep 25, 2011 | 08:05 PM
Hef's Avatar
Hef
Gusto,
Small world - I made the HNVS system (FLIR) when I worked in El Segundo CA at Hughes Aircraft, now Raytheon. I know they installed them on the Osprey and other aircraft.
Old Sep 25, 2011 | 08:07 PM
Paul L's Avatar
Paul L
NAPA units work well with a life-time guarantee.
Old Sep 25, 2011 | 09:32 PM
Vettekid1992's Avatar
Vettekid1992
DONT PUT LIP SEALS IN!!!!!!!!! PUT THE O-RING KIT IN!!!! YOU'LL BE HAPPY YOU DID
Old Sep 26, 2011 | 07:08 AM
Hef's Avatar
Hef
Can I put O Ring seals in the front and keep the rear calipers as is? (lip seal and working)
To Caliper Recommendations
Old Sep 26, 2011 | 07:47 PM
gdh's Avatar
gdh
Here's my question then regarding brakes. My primary driving is cruising with my wife, no more track runs. Are the kits offered bt Baer, Wildwood etc. really that much better than the ones mentioned above. They are 6 - 10 times the cost of the Napa, Autozone etc. It may seem a silly question to some but for regular street use would I really notice that much of a difference. Anyone who upgraded to one of these high end systems I'd love to hear from you. I keep the maintenance fully up to date and next spring I am looking to do the brakes. In a few yrs when the current tires need replacing I plan on moving to 17/18" rims and tires.
Old Sep 26, 2011 | 08:47 PM
GUSTO14's Avatar
GUSTO14
gdh, I'll take a shot at answering your question by telling a little story...
In 1977 I bought my first new Corvette. An L-48 automatic that was loaded with power everything. The A/C would freeze you out and the power brakes would pin you in the seatbelt! I would wager that a well maintained "power brake" system on one of these cars will never disappoint you.
I did keep the car for 6 years but sold it to by a new C4 (which I still own) and one reason was that the brakes on the C4 were even better than the brakes on my '77. A few years later I did pick up a '73 convertible with 4-speed to play with. Unfortunately, with no power brakes, boy did it open my eyes. I autocrossed it for 3 years in Hawaii and even with a perfect system and Hawk pads, couldn't approach the stopping power of my '77.
I guess my answer to you would be that yes the Baer and Willwood systems are good and for serious performance driving maybe even indispensable, but the stock system will perform superbly if maintained well.
Good luck... GUSTO
HEF, absolutely, you can run "O-rings" in front, back or both with no adverse issues...
Old Sep 26, 2011 | 08:59 PM
Ganey's Avatar
Ganey
One time I did a bunch of 0-100-0 runs one after the other & the brakes faded & had to stop w/ the pk. brake when engine/gears slowed it enough.
