aircon clutch
Old Sep 27, 2011 | 08:59 AM
riverracer au's Avatar
riverracer au
Default aircon clutch
is there a way to test the electric compressor clutch on a '72 system?
do i just put power to the terminal, and should it lock up or i feel a drag?
does the rest of the system need to operational?
just getting ready for summer down under
thanks
Old Sep 27, 2011 | 09:26 AM
Ganey's Avatar
Ganey
If you put power to it you should hear the click of the clutch. Clutch w/ power on & belt on lock up.
You can try to turn the center part to see if the comp. is locked up first.
"does the rest of the system need to operational? "
No
