oil pan
Old Sep 28, 2011 | 01:12 PM
big_beau408's Avatar
big_beau408
Default oil pan
Is it possible to drop and change the oil pan gasket on my '74 w/o lifting the engine? Thanks
Old Sep 28, 2011 | 01:23 PM
beachcomber's Avatar
beachcomber
Don't you just have to drop the steering linkage?
Old Sep 28, 2011 | 01:24 PM
MelWff's Avatar
MelWff
Correct drop the steering linkage and the pan comes off.
Old Sep 28, 2011 | 01:27 PM
big_beau408
thanks guys!!!!
Old Sep 28, 2011 | 03:31 PM
scottyp99's Avatar
scottyp99
Give some thought to replacing the rear main seal as long as you are already in there. Also, you might wanna drop the number one main bearing cap and see what the bearing looks like, it's the farthest one from the oil pump, so it'll give you a good indication of what condition the rest of them are in. Neither procedure is particularly difficult, but there are a few thing that you need to be aware of, so if you are interested, say so, and someone will get you up to speed. While the pan is off, clean it up real nice and give it a few coats of the appropriate color engine block paint while you are at it.
Scott
Old Sep 28, 2011 | 03:36 PM
scottyp99's Avatar
scottyp99
Not true!! You also have to unbolt the oil pan bolts, THEN the oil pan comes off.
Captain Obvious
Old Sep 28, 2011 | 03:59 PM
MelWff's Avatar
MelWff
yes but first you have to get the car up off the ground!
Old Sep 28, 2011 | 04:08 PM
wyocat's Avatar
wyocat
and drain the oil... you don't have to but it makes the cleaner....
Old Sep 28, 2011 | 07:48 PM
LannyL81's Avatar
LannyL81
And remove the starter so the inspection plate comes off.
And remove the oil filter...makes geting that back bolt a bit easier and getting the inspection cover off.
I just took the two bolts out of idler arm to drop the steering linkage.
Old Sep 28, 2011 | 10:22 PM
scottyp99's Avatar
scottyp99
Ladies and Gentlemen!!!! Say hello to Major, Colonel, and General Obvious!!!!
Captain Obvious
Old Sep 28, 2011 | 10:31 PM
spinadog's Avatar
spinadog
...and hope your buddy is dead accurate with that 5-pounder he's wielding as you're holding the pickle fork.
Old Sep 28, 2011 | 10:44 PM
scottyp99's Avatar
scottyp99
(Guy holding pickle fork): OK, when I nod my head, you hit it!!!! LOL!!
Scott
Old Sep 29, 2011 | 01:46 AM
big_beau408
LOL!! thanks guys
Old Sep 29, 2011 | 06:18 AM
Carlos840's Avatar
Carlos840
Epic win!
Old Sep 29, 2011 | 03:31 PM
scottyp99's Avatar
scottyp99
See, sometimes when you post a question on the Corvette Forum, not only do you get an answer, you also get a little comedy on the side! Thank you, thank you, I'll be here all week!! Drive safe and don't forget to tip your waitress!!
Scott
Old Sep 29, 2011 | 11:37 PM
Scott1980's Avatar
Scott1980
Oil pump replacement could be something to consider while oil pan is off. Replaced mine while we had pan off.
Old Sep 29, 2011 | 11:51 PM
scottyp99's Avatar
scottyp99
OH!! Yeah, I forgot about that! Might as well, a new stock oil pump is pretty cheap, and it's just cheap insurance.
Scott
To oil pan
