Largest tires with standard trailing arms
Old Sep 29, 2011 | 10:33 AM
myc3's Avatar
myc3
Default Largest tires with standard trailing arms
I recently removed the original trailing arms on my 77. I then purchased a a set of rebuilt trailing arms. They are not offset.
Can some tell me the widest tires I can fit on a 77 with standard trailing arms and what changes are required to make them fit?
Old Sep 29, 2011 | 11:02 AM
gkull's Avatar
gkull
Just go buy 12X17's or 18 inch rear wheels with 5 inch Back space. The largest modern high performance are 335 or 345 width.
Old Sep 29, 2011 | 11:21 AM
glackore's Avatar
glackore
Yep, gkull is right. You should be able to run a 5" backspace wheel without trailing arm interference. However, always measure for backspace before buying. Also, some guys have had to remove the rear sway bar for tire clearance (if equipped). Tire size and wheel width is dependant upon what look you want.
Old Sep 29, 2011 | 11:40 AM
Maymyvetteliveforevr's Avatar
Won't the parking brake bracket on the T/A have to be relocated in order to accommodate the sizing suggested?
Old Sep 29, 2011 | 12:02 PM
69 Chevy's Avatar
69 Chevy
I could fit 275/60-15 on 8.5" rims. I had to pull the e-brake cables inward to keep from rubbing the sidewall.
Old Sep 29, 2011 | 12:44 PM
glackore's Avatar
glackore
I didn't need to relocate mine. I have about 1/2" clearance. That is why you'd want to check backspace on your car - some Vettes are slightly different.
Old Sep 29, 2011 | 12:50 PM
gkull's Avatar
gkull
i don't have any problem with my 335 or 12 inch wide slicks
Old Sep 29, 2011 | 02:48 PM
hugie82's Avatar
hugie82
255-60/15 BFGoodridge was about the limit in my 82 without modification
Old Sep 29, 2011 | 02:59 PM
opnwide's Avatar
opnwide
Gkull, are you saying that a 335 viper tire will fit under the back of a stock C3 without fender flares? I'm looking at mine and a 335-30-18 pilot PS2 I have in my garage and I don't see it happening.
I've also got a 285-35-18 and that looks much more realistic...
Old Sep 29, 2011 | 03:22 PM
myc3's Avatar
myc3
Thanks for the advice. Can you please describe how you check the backspace and how you install.
Old Sep 29, 2011 | 04:04 PM
gkull's Avatar
gkull
I ran around for years withe the tires outside. then I put on Flares. I had 285/40/17 and they filled the wheel well nicely
Old Sep 29, 2011 | 04:31 PM
Ralphbf's Avatar
Ralphbf
Ya but your in Nevada.
In California you would not get buy with it.
If they can make money they will ticket you.
I refer to it as a Sin Tax.
Old Oct 3, 2011 | 10:05 AM
blckslvr79's Avatar
blckslvr79
285 fits in wheel well nicely.
Old Oct 3, 2011 | 10:36 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
285/40/18 is the proper height at 27in and the parking brake bracket is inside the rim. You can go with 5 or 5.5in bs a 285/35/18 is too small at less than 26in.
Do your homework before you buy tires and wheels, ever try and take back tires and wheels that have been mounted ? ( someone's gonna say they have )
Old Oct 3, 2011 | 12:01 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I made a test-fit on mine using a 18X9.5 with 5 in BS and a 295/35-18 tires, the parking brake is inside the rim but the cable itself will hit the tire sidewall, also I feel it would look much better with a 5.5 BS, so the best solution is to get a off-set arms.
Old Oct 3, 2011 | 04:21 PM
Ralphbf's Avatar
Ralphbf
I ordered my rims through America's Tire. They said they would mount several sizes of tires until I was happy.
Old Oct 3, 2011 | 05:11 PM
v2racing's Avatar
v2racing
On both my 75 and my 80 the 285/40/18 tires fit very well with 5" backspace, but they would both hit the parking brake cable bracket with a 5 1/4" backspacing. The tires fit within the fenders better with 5 1/4" to 5 1/2". My 75 is getting VB&P offset trailing arms.
To Largest tires with standard trailing arms
Old Oct 3, 2011 | 09:37 PM
MotorHead's Avatar
MotorHead
So they are going to pay shipping to and from your place if thats the case you aint gettng more that 2 sets ? That's what I am talking about, actually to find a shop that will spend the time and effort to let you try different rims and sizes are few and far between, after the third set I bet they start to tell you those ones look great
Old Oct 3, 2011 | 11:46 PM
Ralphbf's Avatar
Ralphbf
I've been doing business with these guys a few years now and they are customer orentated. The guy I've been working with on this project, Gaylen, seems pretty sharp.
We know about what were looking for so if the Big ones dont fit then we'll know what will. I'm waiting for the 17" rims to show up. 50 series tires are the right height and were hopeing for 275 on the rear and 255 on the front. I don't remember if it's a 5 or 5 1/4 offset.
But we'll see how it goes. I'm hoping the 50 series tires don't look like SUV tires. Then I'll have to do some rethinking.
Ralph
Old Oct 13, 2011 | 06:13 PM
opnwide's Avatar
opnwide
HamadUp,
How about just cutting off that parking brake bracket and rewelding it to the top of the control arm? Will that give you the clearance you need?
