mini starter wiring?
Old Sep 30, 2011 | 08:56 AM
73C34me's Avatar
73C34me
Default mini starter wiring?
Have a CVR gear reduction mini-starer & MSD ignition. I am installing a new wiring harness and am not sure what wires to use. The red, for sure, but is it the yellow or the purple wire, since there is no need for a R terminal. thnx,
Old Sep 30, 2011 | 09:06 AM
Gordonm's Avatar
Gordonm
Purple wire. That is the one for the starter. The yellow is the resistance wire for the points.
Old Sep 30, 2011 | 11:17 AM
73C34me's Avatar
73C34me
Thanks Gordon. I believe that you recently covered this in another thread, but my search did not yield it.
Old Sep 30, 2011 | 12:35 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
The yellow wire isn't needed if you're running an MSD ignition. You will have already sourced a full 12v (or full current) to the ignition bypassing the factory cotton insulated resistor wire.
Old May 19, 2024 | 08:10 PM
rilovin's Avatar
rilovin
Default destination of a battery cable
How RUDE!!!The post might be dead for 15 years; but I'm not; and I wasn't on this forum 15 years ago since I haven't owned my 1957 C1 that long!!! I; being a former Car Mechanic (60 years ago); figured it out my self! Concerning the starter solenoid :Battery ground goes to terminal B; battery plus goes to terminal A; and terminal R goes to the resistor.
Old May 19, 2024 | 10:43 PM
augiedoggy's Avatar
augiedoggy
The conversation you responded to is from 13 years ago and I dont think your replying in the correct thread/conversation as no one has spoken to you or replied to you in this conversation other than this response.
Old May 20, 2024 | 02:00 PM
vettebuyer6369's Avatar
vettebuyer6369
You might have meant to post in another thread.
To mini starter wiring?
