Intake swap = more jet ?
Old Oct 2, 2011 | 07:47 AM
boltnut's Avatar
boltnut
Default Intake swap = more jet ?
In swapped from a stock replacement manifold to an edelbrock Air gap manifold. Do you suspect I'll need to go up one size in jets ? Exhaust is still OE (for now)....
Old Oct 2, 2011 | 06:37 PM
MelWff's Avatar
MelWff
If you mean the Edelbrock RPM Air Gap the instructions indicate minor richening may be required. On the other hand you may want to hold off till you switch to headers.
Old Oct 3, 2011 | 10:41 AM
gcusmano74's Avatar
gcusmano74
Don't change anything until you see how the new combination runs. You may be just fine without changes. Increasing jet size may just increase your fuel consumption. Sometimes a slightly lean carb gives a nice crisp throttle response.
Old Oct 4, 2011 | 09:06 AM
boltnut's Avatar
boltnut
it was running crappy so first thought was lean......found a bad float in the secondaries....
Old Oct 5, 2011 | 03:46 PM
Rally68's Avatar
Rally68
Do you have a stock hood and if so does that manifold fit?
Old Oct 5, 2011 | 03:56 PM
boltnut's Avatar
boltnut
yes sir ! i have a 73 though......
To Intake swap = more jet ?
