Power window question
Old Oct 3, 2011 | 03:17 PM
Camss57's Avatar
Camss57
Default Power window question
I just replaced the window motor in the driver side of my 80. The switch fell apart right when I got finished. I tried a repo switch and the window still won't work. I also tried using the switch from the otherside and I plugged in the old motor and it didn't work either? What am I missing and what should I check next? The passenger side still works fine. Thanks!
Old Oct 3, 2011 | 04:01 PM
MelWff's Avatar
MelWff
Did you check the wire harness going from the door to the body?
Old Oct 3, 2011 | 04:38 PM
Camss57's Avatar
Camss57
I'll go out and check that next..
Old Oct 3, 2011 | 04:46 PM
...Roger...'s Avatar
...Roger...
its common to find a break in the rubber between the body and door
edit - let me add this just in case. 2 wires (brown and blue)go through the door for the motor,both are made hot by the switch,one up and one down,the ground for the motor is the door frame.
Old Oct 3, 2011 | 06:01 PM
Camss57's Avatar
Camss57
I'm going to have to check it closer. I intermently get some juice. Here is what I have been working on for the last 4 years. Sadly though I think it will be up for sale once I get all the bugs worked out.
Old Oct 3, 2011 | 06:05 PM
...Roger...
Nice !
( I added a little info to my above post).
Old Oct 3, 2011 | 06:12 PM
Camss57's Avatar
Camss57
I loaned out my test light to a buddy, so I will have to pick that up tomorrow and see if I can find the problem.
Old Oct 4, 2011 | 04:26 PM
Camss57's Avatar
Camss57
Well the test light shows power to the harness. If I plug in the old motor and ground it, it works. The new one does not. It has to be the new motor right? I was only able to get the window to roll up then the switch broke. now with a new switch nothing from the new motor. Now how can I replace the motor with the window all the way up?
Old Oct 4, 2011 | 04:46 PM
...Roger...
Just put some plastic squeeze clamps on the glass , remove the 3 bolts , and pop the motor out. The clamps will keep the glass up.
Old Oct 4, 2011 | 06:06 PM
jdp6000's Avatar
jdp6000
Sometimes there is corrosion where the regulator makes contact with the door frame and prevents a good ground. Try a couple of last things. Run a black wire from the battery negative to the door metal...see if it works...if not run it to the regulator metal.....see if it works....if not run it to the motor....see if it works. If it does you have some cleaning of corrosion to do.
Clean up the contact points between where the motor attachs to the regulator or where the regulator attachs to the door frame. Or solve a bad ground issue to the door frame.
Old Oct 4, 2011 | 09:02 PM
Camss57's Avatar
Camss57
I guess what I don't get is why the old motor worked but was just getting a little weak. Now the new one doesn't want to work for me. I'll check all the contacts, but the doors where all apart and I didn't really see any corrosion. So where exactly does the motor get grounded? Could it be that the new motor is completly painted and the old one was not?
Old Oct 4, 2011 | 10:55 PM
jdp6000's Avatar
jdp6000
It could always been the ground. You have two wires from the switch. One up and one down. There is no ground is there? Dont guess. Turn the key to on. Push the switch to up or down and hold it. With the wire you ran from the negative from the battery touch the door then the regulator then the metal housing of the motor. See if it works. I don't know how your door grounds. I have a black wire.
Old Oct 5, 2011 | 11:14 AM
Hef's Avatar
Hef
Camss57,
Your symptoms are similar to what I experienced recently. The window would work intermittently, and it was caused by the window switch contacts.
In your case, its possible it is something other than the switch but has the same symptoms.
Take a look at how I made the repair with the link below.
http://forums.corvetteforum.com/c3-t...eshooting.html
Old Oct 5, 2011 | 12:46 PM
Camss57's Avatar
Camss57
Thanks for the input guys. Working a 24 hour shift today, so I'll tackle this again tomorrow. I sure hope it's just the ground.
Old Oct 6, 2011 | 04:51 AM
demoke's Avatar
demoke
i went through all the things you have mentioned, even bought a new pw motor- the culprit was a broken pw wire inside my door jam. you have to pop out the rubber seal to check. good luck...
Old Oct 6, 2011 | 03:13 PM
Camss57's Avatar
Camss57
Okay, I pulled the new motor out and grounded it to the battery and it works. So just like jdp6000 thought, it was the ground. I put the old motor back in to get the window down halfway and it works just fine? I am cleaning eveything up in the door, but it all looks pretty good. Strange how the old one works in the car and the now one doesn't. Before I put it back together to see if it works I have a question about the gear for the motor. I have 2 gears. One seems pretty tight if I hold the outer edge and try to move the smaller gear back and forth. The other one moves about a quarter of a turn. Which gear is working properly?
Old Oct 6, 2011 | 03:33 PM
jdp6000's Avatar
jdp6000
I don't know about the gears. As for the grounding, I believe the old motor casings are 100% metal, the new crap mixes alloys. They are poor conductors and therefore more sensitive. You may want to run a secondary ground wire from the metal on the door to one if the bolts that hold the window motor. What make motor did you get by the way. I paid $160 for a Delco from the dealer, it was much heavier.
To Power window question
Old Oct 6, 2011 | 04:07 PM
Camss57's Avatar
Camss57
The motor I got was a Cardone. It was the same brand at three of the 4 parts stores I checked at. They rebuild old cores, so I don't know why it would be that much different?
Old Oct 6, 2011 | 04:24 PM
Camss57's Avatar
Camss57
Just went out and checked them side by side. New one has a different case. They must just use the guts for the rebuild? I stuck a magnet on both and it stuck in all the same places.
Old Oct 6, 2011 | 05:33 PM
jdp6000's Avatar
jdp6000
There is nothing wrong with the aftermarket stuff for the price. It will work. You have to admit though its interesting the old will work but the new will not. Just groundit right and get it working.
