1968 427/400 Cooling
Old Jun 21, 2012 | 01:34 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
After you get that Top Flight ribbon, switch from a ported vacuum source to a full manifold vacuum source for your distributor vacuum advance. Your engine will love it and run cooler. Who gives a rats azz about emissions anyways.........enjoy driving it.
Old Jun 21, 2012 | 02:00 PM
PRNDL's Avatar
PRNDL
It's not going to help anyone get Topflight, but I experienced an amazing drop in running temps after installing coated headers.
Old Jun 23, 2025 | 08:34 AM
Jojo33's Avatar
Jojo33
Originally Posted by 69MA
I had the same problem. I did everything new shroud, shroud extension, seals, thermostat (with hole drilled in it), new fan clutch... Nothing worked, some things made a little difference but nothing that would make the car stop over heating. I would stop at a light in the summer and i would watch the temp gauge rise. Also if i held on to the shifter, not the ball at the top the shaft that comes up through the floor, it was hot. All the time talking to a friend who owns a restoration shop and he was telling me the timing is not right and i need to advance it. Long story short I email Lars to get his paper on timing read it until i understood it. I then set the timing up per his recommendations and it's like night and day. It's running cool, I can grab the shifter and it's just warm. So far so good one more test today it's supposed to be in the upper ninety's i will go for a ride tonight when i get home from work. I'm confident that the problem is pretty much resolved.
Where can i get the timing documentation you mentions from Lars on timing. I also am having an issue with over heating on my 68. I do have to install new heater core and hoses, as the previous caretaker cur the heater core out of the cooling circuit and looped that from the intake to the water pump. The radiator in the care right now is a griffen aluminum rad. seals seem to be all there around the shroud. It does have a MSD ignition.
Old Jun 23, 2025 | 11:19 AM
MelWff's Avatar
MelWff
You can reach Lars at V8fastcars@msn.com and you should start a fresh thread this is 14 years old.
Old Jun 27, 2025 | 01:25 PM
68/70Vette's Avatar
68/70Vette
I wonder if the block is essentially untouched. The block is 57 years old. The water passages are very likely covered in rust scale of some unknown thickness. I would imagine this contributes to a lack of cooling capability. I've seen a YouTube video were someone fills the block coolant passages with an acid solution acid, during block restoration, to clean out the passages.
Old Jun 27, 2025 | 08:48 PM
bashcraft's Avatar
bashcraft
Cast iron doesn’t rust like steel does, which is what you’re describing.
