Ignition warning buzzer install
Old Oct 4, 2011 | 08:38 PM
spoonhead76's Avatar
spoonhead76
Default Ignition warning buzzer install
Does anyone have pictures of how the warning buzzer should be installed?
I wasn't the one that took the steering column apart so I am trying to figure out how it goes back together without any first hand information. I'm getting close to having the column back together but I just can't see how this part fits and works. It is a 76 if it matters.
How does this:
Fit into this:
Thanks,
Joe
Old Oct 5, 2011 | 08:14 AM
Jim Shea's Avatar
Jim Shea
There should be complicated, small leaf spring that hooks to the switch and sort of locks the switch into the rectangular slot in the turn signal switch housing. There are different switchs. You have a T&T steering column so make sure that you have the correct switch and spring.
The two metal contacts on the switch should touch two seperate contacts on the underside of the turn signal switch.
Jim
Old Oct 5, 2011 | 08:17 AM
spoonhead76
Thanks Jim.
I have a box of steering column parts that I will dig through to see if the spring is there.
To Ignition warning buzzer install
