HELP appreciated: Hood release cable broken on C3
Old Oct 6, 2011 | 08:53 AM
lambotom's Avatar
lambotom
Navigator
Default HELP appreciated: Hood release cable broken on C3
HI all,
The front hood (bonnet) release cable broke (or got loose) and came all the way out on my 1971 LS5 454 convertible. Any suggestions on how I can get the hood to open again? thanks!
Tom
Old Oct 6, 2011 | 09:40 AM
MelWff's Avatar
MelWff
If you do an advanced search using 'broken hood cable' in the C3 forums you will find this and other links
http://forums.corvetteforum.com/c3-g...ase-cable.html
Old Oct 6, 2011 | 12:54 PM
John 65's Avatar
John 65
That notch thats formed in the hood, its in line with the latch. GM had to put it there for a reason. Grab a screwdriver, go easy, and see if you can pop it. Good luck.
Old Oct 6, 2011 | 01:56 PM
1970LS5's Avatar
1970LS5
When I had a similar problem with my 1970 coupe, I removed the fender grille and had complete access to the latch release mechanism. Simply reach up and release the latch.
Gene
Old Oct 6, 2011 | 03:11 PM
MIKE80's Avatar
MIKE80
http://www.mamotorworks.com/corvette?frame=1.3852
Good luck!
Old Oct 7, 2011 | 02:46 AM
Solid LT1's Avatar
Solid LT1
Gene
When it comes to broken cables the 70-72 Vettes are the ultimate Vette as the side grille makes this task pretty easy!
To HELP appreciated: Hood release cable broken on C3
