OT--98 sonoma..surging
Old Oct 8, 2011 | 11:03 AM
onaqwst's Avatar
onaqwst
Default OT--98 sonoma..surging
have this issue of my truck surging when i stop... it's so bad that it causes my truck to stall and this didn't start happening until my transmission was replaced 2 years ago... the issue is worse now so i think i might have narrowed it down to either the egr valve or the rubber hose that the shop hacked in instead of running my trans hard line to the radiator..... if it the rubber hose, i think i might be compressing on itself and cause it to stall.... when i put the truck in neutral it doesn't do it..... curious if it could be the cat.convertor also... any ideas
Old Oct 8, 2011 | 02:46 PM
MelWff's Avatar
MelWff
is the check engine light on?
Old Oct 8, 2011 | 11:45 PM
onaqwst's Avatar
onaqwst
the check engine light has been on for 5 years.... i disconnect the battery for 30 min then reconnect and the light is gone... but when i drive the truck and it surges then it comes back on.....truck has 230,000 on it and is a 4cyl... trying to keep it on the road till the spring...
Old Oct 10, 2011 | 10:35 AM
onaqwst's Avatar
onaqwst
Trying to figure out if it's an easy fix before i take it to the shop
Old Oct 10, 2011 | 10:43 AM
MelWff's Avatar
MelWff
take the vehicle to autozone or other parts store that does free computer code lookup. You need the code to fix the vehicle.
Old Oct 10, 2011 | 10:46 AM
onaqwst's Avatar
onaqwst
ok, will do.... thanks... if i have to drop over a grand into this truck again, i think i'll scrap it and upgrade
To OT--98 sonoma..surging
