82 spark plugs - remove/install
Some guys use a plug socket turned by an open end wrench instead of a ratchet. Others have cut off a little of the open end of a plug socket to make it short enough to fit into tight places. Got to get creative and think outside the box sometimes.
Terry
1. Jacked front of car up, put on stands.
2. Disconnected battery, alt (just to get wires out of way), and spark plug wire 4.
3. Removed exhaust manifold heat shield. See image:
4. Removed spark plug #4 with 5/8" socket and 3/8" drive.
5. Inspected corroded plug (oily, wet, gross). Cursed and tossed it.
6. Gapped new RT45S .045 and had girlfriend install.
7. Reinstalled heat shield.
8. Attached plug #4, attached alt wires, attached batt cable, and dropped car.
Started quick and purrs like kitten.
