Brake pad installation
Old Oct 11, 2011 | 11:11 AM
Jim__H's Avatar
Jim__H
Default Brake pad installation
Hi all,
I'm installing new calipers, rotors, and pads on a '77 Corvette. Calipers and rotors went on no problem but I am having trouble getting the pads in. The pistons are spring loaded and do not stay retracted when I push them back into the caliper. There is no room to get anything in to hold them in while inserting the pads. Is there a special tool for this? Also it seems like the springs have enough force to cause the brakes to drag once I get everything together, is that typical? Does this all sound right? The calipers are rebuilds and came from Autozone.
Thanks,
Jim
Old Oct 11, 2011 | 11:13 AM
MelWff's Avatar
MelWff
You need this tool or put the pads in before mounting the caliper using a socket or something to keep the pistons depressed.
http://www.ecklerscorvette.com/corve...1965-1982.html
Old Oct 11, 2011 | 11:20 AM
Mike Ward's Avatar
Mike Ward
Insert a socket or lump of wood slightly wider than the rotor between the pads then push the caliper into place.
Old Oct 11, 2011 | 11:46 AM
Jim__H's Avatar
Jim__H
Thought about cutting some wood wedges but they would be a pain to fish out of the inboard side once they got pushed out of the way. For 8 bucks I'll get that tool.
Thanks!
Old Oct 11, 2011 | 12:58 PM
MelWff's Avatar
MelWff
There is no inboard/outboard side. The pads are placed in the uninstalled caliper. The pistons are pressed in and you place 1 socket or 1 piece of wood between the pads to hold the pistons in. You slowly slide the whole assembly over the rotor and the socket or wood is pushed out by the rotor.
Old Oct 11, 2011 | 01:29 PM
7t9l82's Avatar
7t9l82
that is why i leave the springs out. now I'm sure everybody on the forum will tell me why that's wrong etc.............
Old Oct 11, 2011 | 01:36 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Corvette disc brakes are designed to have the pads in contact with the rotors at all times. They should never retract.
If it were me, I would put the springs back in.
Old Oct 11, 2011 | 02:15 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
Use the tool or do like me and Mike a small block of wood works great.Ron
Old Oct 11, 2011 | 03:00 PM
SteveG75's Avatar
SteveG75
I have also used a large putty spatula to hold the pistons in while swapping pads. Worked fine for me.
Old Oct 11, 2011 | 03:56 PM
Ganey's Avatar
Ganey
I use a piston retaining clip & do not remove the calipers. Fast.
Old Oct 11, 2011 | 04:55 PM
garage-ghost's Avatar
garage-ghost
Old Oct 11, 2011 | 06:23 PM
Hammerhead Fred's Avatar
Hammerhead Fred
This is the easy way to install pads with the caliper on using a wide blade putty knife.
Set the pad against the knife with the top just touching the handle.
slide the exposed bottom of the blade into the caliper and press back against the pistons.
Once you have the pistons depressed simply push the handle down further into the caliper and the pad goes too.
Quick and easy.
Old Oct 11, 2011 | 07:30 PM
themetalman03886's Avatar
themetalman03886
I put the pads on then installed the caliper. My problem was the rotors, damn originals, had to drill the rivets out
Old Oct 11, 2011 | 07:39 PM
Mike Ward's Avatar
Mike Ward
Why?
Old Oct 11, 2011 | 08:29 PM
themetalman03886
Factory installed rotors were installed with rivets. Only way to get the rotors off was to drill the rivets out.
Old Oct 11, 2011 | 08:31 PM
Mike Ward's Avatar
Mike Ward
I'm asking why you needed to take the rotors off to install new pads.
Old Oct 11, 2011 | 08:56 PM
themetalman03886
Oh haha I replaced the rotors as well
Old Oct 12, 2011 | 12:58 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Ganey
...I use a piston retaining clip & do not remove the calipers. Fast....
Using two is twice as fast.
To Brake pad installation
