My timing was wrong!
Old May 3, 2002 | 08:58 PM
Wrecked82's Avatar
Wrecked82
Default My timing was wrong!
Found out it was at 15 degrees BTDC, not the specified 6 degrees. No wonder it liked premium gas! Moved it back to 8 degrees. So, what does having too much advance do?
[Modified by Larry82, 7:07 PM 5/3/2002]
Old May 3, 2002 | 10:07 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Default Re: My timing was wrong! (Larry82)
Larry, too much advance kills power in two ways. By causing the fuel mixture to ignite too soon, it doesn't burn as efficiently. The other way is that it is creating a downward force on the piston while it is trying to go up. Besides using up the energy that would otherwise have been available for pushing the piston down on the power stroke, more of the power that is being developed in the opposing cylinders is being consumed to overcome the extra resistance of the firing cylinder.
Some basic things to consider are that "more isn't always better" and that anything that is added to inititial is added to total. An engine may feel stronger with more initial but if it results in too much total, you'll wind up actually losing power. The best way is to set timing at total and then, if necessary, adjust the curve so that initial is compatible.
Old May 3, 2002 | 10:24 PM
Wrecked82's Avatar
Wrecked82
Default Re: My timing was wrong! (Vetterodder)
Yeah, I think before the weekend is over, I will set it at the spec 6 degrees.
Thanks.
Old May 4, 2002 | 04:48 PM
Twin_Turbo's Avatar
Twin_Turbo
How did you check it? If you don't disconnect the HEI bypass lead you won't read static timing!
Marck
Old May 4, 2002 | 07:11 PM
Wrecked82's Avatar
Wrecked82
Default Re: My timing was wrong! (Twinnie)
No, did disconnect it. Been down that route before. I don't think it was ever really checked properly since someone and I changed out my intake manifold. Bought a dial-back timing light and found out I was off that much. Car starts and runs differently. Have not had a chance to take it over 35 mph or so yet.
To My timing was wrong!
