Intake manifold max height
Old Oct 11, 2011 | 02:35 PM
tmc812's Avatar
tmc812
6th Gear
Default Intake manifold max height
I have a 69 coupe with original 350 hood. 388 stroker roller setup, but still original L46 intake and Jetted Q-Jet. I figure I will need 1" or more drop base filter and I want to go with single plane (Team G 7530 is only 4.09" to carb pad or shortest Vr. Junior) or high RPM dual plane like Weiand air strike and Holly 750. I don't want to modify or change hood. Does anybody know how tall I can get (carb pad height) before running into problems? On the same note, does anyone know the carb pad height on the original intake #3927184 is?
Old Oct 11, 2011 | 03:00 PM
DRIVESHAFT's Avatar
DRIVESHAFT
With a Performer RPM or a Weiand "Air Strike" you will need to run a deep dropped air cleaner base and a 2" tall filter to clear the hood.
Per Holley's published data, the 7530 Team G is actually about 1/2" shorter than the RPM, so you could run a bit more filter height.
Old Oct 11, 2011 | 03:11 PM
Ganey's Avatar
Ganey
There is minimal clearance w/ the std. flat hood so the 7530 would be best single plane if it can be fitted. 2nd 2101 would work in a dual plane. The LT-1 hood provides minimum clearance for hi rise intakes.
There needs to be at least about 3/4" clearance over the Holley vent tubes.
Old Oct 11, 2011 | 03:17 PM
tmc812's Avatar
tmc812
6th Gear
I have been thinking that is probably the way to go. My hope is that it won't sacrifice a ton of torque down low compared to the dual plane. The car is a 4 speed so power band starting at 2800 shouldnt be too bad.
Old Oct 11, 2011 | 03:41 PM
Ganey's Avatar
Ganey
FYI There is another intake about stock height that would work w/ either Q-J or Holley, the discontinued Weiand 7525 Street Ram single plane esp. if you like the Q-J.
I would go for the 7530 & Holley.
Old Oct 11, 2011 | 04:02 PM
tmc812's Avatar
tmc812
6th Gear
I think the Weiand X-CELerator 7547-1 is the shortest of the single planes at 3.5" and the band is 1500 to 6500 like Edelbrock RPM, but single plane instead of dual. Anyone run one of these?
Old Oct 11, 2011 | 05:03 PM
DRIVESHAFT's Avatar
DRIVESHAFT
I dont know anyone who has run that intake, but in general tiny flat plenums like that dont work well.
I would expect better performance out of either of the other intakes you asked about.
Old Oct 12, 2011 | 12:03 AM
ra.geiser's Avatar
ra.geiser
8th Gear
Yes, i have the X-cellerator with a street avenger 670 and 1/2"alu 4 hole spacer on top of my 355 ci.
With the proform dropbase aircleaner botom and 3" fillter wil fit about of 1/4" clearence under my 69 hood.
raphael
Old Oct 12, 2011 | 07:21 AM
69mlc's Avatar
69mlc
2nd Gear
i have a l46 and currently waiting delivery of weiand 8125 manifold.i have a drop base air cleaner and a 650 holley dpumper with a std hood i reakon thats my limit for clearence. manifold measures 3.5'' at front.
Old Oct 12, 2011 | 11:05 AM
GT's 78's Avatar
GT's 78
Were the earlier C3 hoods shorter than the later years?
Old Oct 12, 2011 | 11:08 AM
Ganey's Avatar
Ganey
Yes, we have the med. rise hood 73-79.
Old Oct 12, 2011 | 09:47 PM
tmc812's Avatar
tmc812
6th Gear
raphael
How do you like the x-cellorator
Old Oct 12, 2011 | 11:58 PM
ra.geiser's Avatar
ra.geiser
8th Gear
I use the x-cellerator with the voodoo 60104 cam from lunati.
About 2000 rpm, engine runns like a `bag of potato` but from 2000-6000 and mor, it runns very strong.
The x -cellerator is a little bit radical, dat`s way i use a 4 hole spacer.
In combination of a 4 speed trans. It works.
The answer of your question, yes i like the x-cellerator.
raphael
Old Oct 13, 2011 | 08:20 AM
njfl's Avatar
njfl
I have a similar setup (383) in a 69 with stock small block hood and run a Victor Jr., 750 Holley Double Pumper (no choke or choke tower), and dropped air cleaner without problems. You're welcome to come by anc take a look this weekend. I'll PM you my info.
Old Oct 13, 2011 | 01:16 PM
tmc812's Avatar
tmc812
6th Gear
How much of a drop base did you have to run? Any other provisions? I appreciate the info - I'll try to touch base with you when I have an opportunity.
To Intake manifold max height
