Expansion Tank
Old Oct 12, 2011 | 08:36 AM
bill69's Avatar
bill69
Default Expansion Tank
My expansion tank is corroded..is there a difference between the big block and small block expansion tank in 1970? Everywhere i look says small block expansion tank...none say big block. The pictures they have on the websites look the same as my big block tank though.
Thanks.
Old Oct 12, 2011 | 08:42 AM
bashcraft's Avatar
bashcraft
Thanks.
Ecklers is listing this one for big block cars:
http://www.ecklerscorvette.com/produ...18585/image/0/
It sounds like your car was originally a small block.
Old Oct 12, 2011 | 09:20 AM
bill69's Avatar
bill69
That is the expansion tank if you have air conditioning....my car is all original numbers matching so it was originally a big block car.
Old Oct 12, 2011 | 09:23 AM
bashcraft's Avatar
bashcraft
Well, then I guess non air cars used the small block tank.
Old Oct 12, 2011 | 09:52 AM
Mike Ward's Avatar
Mike Ward
Here you go:
http://www.dewitts.com/pages/product....asp?ProdID=94
Old Oct 12, 2011 | 10:32 AM
bill69's Avatar
bill69
Thanks that looks perfect.
Old Oct 12, 2011 | 10:41 AM
bashcraft's Avatar
bashcraft
That's also the small block tank.
http://www.ecklerscorvette.com/produ.../9464/image/0/
Old Oct 12, 2011 | 12:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What type of corrosion? The tanks are aluminum. They will oxidize, but usually do not corrode. Will yours clean up?
To Expansion Tank
