1981 Corvette Won't Start - - Help!!
Old Oct 14, 2011 | 05:36 PM
htown81vette's Avatar
htown81vette
Default 1981 Corvette Won't Start - - Help!!
I've been working on my 1981 Corvette replacing the electric antenna, so I've been messin alittle with the wiring, also been around the battery area. Now the car won't start, will turn over, but I checked and I have no spark. I thought at first maybe I tripped the security system, but did alittle research and found that in that case the starter shouldn't even engage. The only other thing I could think of is maybe I fried the ECM when I was working around the battery.
Any ideas why I am not getting any spark?
Old Oct 14, 2011 | 05:57 PM
htown81vette
I also thought maybe I burnt a fuse. But I checked all fuses and they seem to be ok.
Old Oct 14, 2011 | 06:33 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Check to make sure you have voltage to the distributor Bat terminal.
If you do, you should be able to unplug the computer (4 wire?) wiring connector to see if it is having an impact on the spark.
Its been a long time since I messed with an '81, but I think it should still run with the computer connector unplugged.
If I'm wrong about that I'm sure somebody will come along shortly and correct me.
If you have spark with it disconnected, you have a computer issue. If you still don't have spark, its probably your module.
Old Oct 14, 2011 | 07:25 PM
jr105's Avatar
jr105
It should run, you just won't get any spark advance. Unplugging the computer is how you set the base timing.
Old Oct 14, 2011 | 07:36 PM
htown81vette
I disconnected the 4-wire plug going to the distributor, it runs now. Plug it back in, and it doesn't run. ECM fried? I've been wanting to move forward, and really don't want to spend money on a new ECM. Maybe its time to convert...
Old Oct 14, 2011 | 08:32 PM
htown81vette
Would it hurt anything to drive it around with the ECM unplugged like that?
Old Oct 14, 2011 | 11:36 PM
htown81vette
I may have fried the ECM when I put the battery charger on it. I didn't realize you shouldn't do this.
Old Oct 15, 2011 | 12:16 AM
terry82's Avatar
terry82
iy would cost you more to convert your car than to replace the ecm.
Old Oct 15, 2011 | 12:26 AM
htown81vette
I might call around for some ECM's tomorrow, I'm not ready to spend that kinda money on a conversion just yet. Plus, I am suffering from Corvette withdrawals. I need a fix and fast!
Old Oct 15, 2011 | 12:27 AM
htown81vette
Now I know what that funky smell from the battery compartment was, that was circuit boards frying! Never smelt that before...
Old Oct 15, 2011 | 03:13 AM
RC81's Avatar
RC81
I think the ECM is only around $100.00. Remember it does not come with the prom. and use care when swapping it out - its easy to bend one of the pins.
Old Oct 15, 2011 | 07:04 PM
htown81vette
I got a reburbished ECM from O'Reilly's today for $82 w/ exchange. Car runs now, but doesn't run nearly as good, and the check engine light stays on. I didn't do anything special, just plugged it in and started it up. Do I need to reset the timing? Or is it just a matter of the ECM relearning the engine?
Old Oct 15, 2011 | 08:32 PM
Tommy Almond's Avatar
Tommy Almond
ECM needs a few miles to set the system but that should happen in less than 20 miles. On the check engine light, check the codes by the light flashing and counting. You use a screwdriver to connect the 2 prongs in the 5 prong plug under the ashtray. The number of flashes will let you know what system problem is if you have the manual to cross reference. You should get a 12 at first to show that system is operating properly and problem code after that. If light comes on and goes off probably an O2 code but if the light stays on and sets then code will tell you even if it is the prom unit.
Old Oct 16, 2011 | 10:17 AM
LannyL81's Avatar
LannyL81
I assume you did take the PROM out of the old ECM and put into the new one, right?
These PROMs are old and factory ones are no longer available.
Make sure you did not knock the vacuum line to the MAP sensor out. Engine will run...just not real good.
Pull the codes and let us know.
Also suggest the L81 Corvette Registry for questions...all 81 owners there.
Old Oct 16, 2011 | 11:24 AM
htown81vette
Make sure you did not know the vacuum line to the MAP sensor out. Engine will run...just not real good.
Yes, we pulled the old PROM out of the ECM and put it into the new one. They did it at O'Reilly's. I was not real confident that the PROM was seated very well though. I wouldn't think the car would run at all without the PROM, but don't know. I haven't put 20 miles on the car yet. Will pull the codes ASAP.
Old Oct 16, 2011 | 08:12 PM
LannyL81's Avatar
LannyL81
The engine will run with a bad PROM...as mine did..just not really well. The Check Engine Lite will stay on though.
Even just running the engine and varying the throttle to simulate going through the gears will also get the ECM to "learn"....not the best as there is no load...but it helps.
And I meant to type....be sure you did not KNOCK out the MAP sensor vacuum line....gotta with my glasses on anymore.....
Old Oct 16, 2011 | 11:35 PM
htown81vette
Well, I drove the car around for about 40 miles, and check engine light is still on. Then I grounded the diagnostic terminal, and the check engine light, for some reason, would not flash at all. I know this works because a friend that has an '82 did it and was able to retrieve codes.
I will check the vacuum line for the MAP sensor, that very well could be a legit problem. Although it wasn't a problem before I burned up the ECM...just sayin...
And when they took the PROM out, and put it into the new ECM, I swore I saw it spring back up just a tad. The guy swore that it seated properly. I guess I could just pull the ECM out again and take a look.
so...now I got:
1) possible vacuum line to MAP sensor out
2) PROM not seated properly
I'll check these out tomorrow, as we all probably have the same problem, there is just not enough time to do all this stuff....
To 1981 Corvette Won't Start - - Help!!
Old Oct 16, 2011 | 11:51 PM
htown81vette
Also, at WOT, the car sometimes backfires through the carb, spits and sputters. At cruising speed, it runs ok. Idles ok. The timing advance seems to be all off. But then again, the ECM could just be in limp mode. It does run bad, feels like about 150 hp.
Old Oct 17, 2011 | 02:57 AM
RC81's Avatar
RC81
Did they put the prom in facing the correct way? As I recall it has a dot on one side so it can be oriented correctly.
Old Oct 17, 2011 | 08:03 AM
wajulia's Avatar
wajulia
Check the codes before you do anything . If the prom is bad the computer will tell you. To many people try to debug 81's without looking at the codes first -- That is like a doctor operating without asking the patient what the symptoms are. Once you get the codes there are a lot of people that can walk you through the rest. Do you have a service manual -- great help in debugging codes.
The 81 computer does not "learn" and needs no startup time. The check engine light only goes off if the problem goes away.
If you fried the boards on the computer, there is a real possibility you also took out the prom. But as I said, the computer will tell you that the prom is not working correctly.
