Bee Jay's hood lightening mods!
MYBAD79 gave me this hood about two years ago. He modified it to make it a high rise, but otherwise, it's a stock '79 hood. I weighed it, 45lbs, and started removing mass. I got it down to 35 lbs without trying too hard. Next, I will try hard and I think I will vent the hood and remove the paint. Hopefully I can get it down to 30lbs. I think the aftermarket hoods weigh about 35lbs. The brown paper is about where I will cut the vent. I think I'll just mount some black screen under the hole. Maybe the Greenwood fender vents will fit on the hood now that the bracing is gone. Stay tuned.
Bee Jay
Bee Jay
Even my lite weight 81 Twin Turbo hood has the rear cross piece
I had thought of doing this to my 79 hood, but found a good deal on an aftermarket L-88 long hood. It is lighter than stock, but I forget by how much. If I get a chance, over the weekend I will try and get a weight on it for comparison.
Removing that cross support would make me a little uneasy. It gives the hood rigidity against raising and latching at the rear. I'm curious how it works out. Somebody has to step out of the box and try another way. MYBAD79 did a good job raising the center.
First off, I've always admired your willingness to experiment. That said, there being sound reasons to do so, did you give any consideration to sealing the rear of the hood at the cowl?
And, no, I haven't forgotten about weighing my stock and L88 (long) hoods against each other. Just haven't dug them out yet.
Maybe make a mold and then make you a carbon fiber hood, wouldn't that be lighter? Or maybe cut out the center section through the center nd replace with some Plexiglas? If done right it could look pretty good.
Riggs.
Riggs.
Hey, like I said, I was bored. Where is the best place to buy hood pins?
Bee Jay
Bee Jay
Bee Jay
My friend Gill is interested in doing just that. Is there any interest in more than one? You can get a Honda Civic carbon fiber hood for $500. The C6 guys pay $1300 for carbon fiber hoods. I guess a C3 CF hood would weigh about 20lbs. I've thought about a ZR1 style plexiglass window. They had plenty of Camaros with them at SEMA. They are sold for about $600.
Bee Jay
Bee Jay
Riggs
I was also thinking along the same lines as the Plexiglas, but instead use a carbon fiber insert running almost the full length of the scoop. This would lighten the hood, but not as much as a full carbon fiber hood. I don't think a full carbon fiber hood would look right on a C3, I think because it would ruin the flow of the body lines of the C3.
Thanks. Yep, a lotta work to save a few pounds. Just like the aluminum driveshaft, the door side beams, the front and rear bumper removal, and the aluminum batwing. I still have some easy targets to get to like an aluminum radiator and the rack and pinion steering. Maybe some tubular or aluminum a-arms. I really would love an aluminum Gen 1 block. I'm not sure I want to go the LS route. The lighter the car gets, the funner it is to drive.
Bee Jay
Bee Jay
I have an aluminum quick ratio rack with no power steering... if I remember it cost me a hair under $400 all said and done. Thats a "cheap" 10+lbs right there. Add the HP gain from ditching the PS pump and you have a good performance gained per $$ mod
Is your car big block, or small block? Aluminum heads? Just trying to get an idea of how much weight sits over your front wheels, as opposed to my 76' SBC car. I've heard that the road feedback on manual steering is much better than power steering, plus the power increase for one less drive belt, plus a weight savings....BUT, is it a pain in the but to drive at lower speeds? I kinda like power steering....just a matter of weighting the pros and cons...
Sorry for the hi-jack BJ
My 79 L88 style Ecklers hood weighs 25 pounds stripped of brackets.
While i was at it, I weighed an 82 hood that was modified on the underside for a carb and 14 inch air cleaner. It weighed 38.5 pounds and I know my 79 hood weighs more, but not able to weigh it. This ought to provide some comparison with your lightened hood.
Chopped fiberglass is heavy, and maybe as someone suggested, it has to do with resin density. If you can get your 79 hood down anywhere near 25 pounds without it cracking the glass or paint over time, a super discovery IMO.
My 79 L88 style Ecklers hood weighs 20 pounds stripped of brackets.
Chopped fiberglass is heavy, and maybe as someone suggested, it has to do with resin density. If you can get your 79 hood down anywhere near 20 pounds without it cracking the glass or paint over time, a super discovery IMO.
Bee Jay
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Bee Jay
Bee Jay
