cowl induction
Old Oct 17, 2011 | 01:30 PM
flyboy461jd's Avatar
flyboy461jd
Default cowl induction
Did the 73 or any c3 vetts come with cowl induction similar to the Chevelle SS?
Old Oct 17, 2011 | 01:38 PM
Ganey's Avatar
Ganey
Yes, 73 had cowl induction & was the first year of the med. rise hood. Cowl induction could be added to all med. rise hoods through 79.
Old Oct 17, 2011 | 02:13 PM
cv67's Avatar
cv67
St. Jude Donor '05
If youre referring to the little flapper, no.
Doesnt make a difference anyway it wasnt much more than a novelty albeit a cool one.
Old Oct 17, 2011 | 02:27 PM
flyboy461jd
Is there any web site that I can find out more information on this? My vette has a partical system but I don't know what is missing.
Old Oct 17, 2011 | 02:39 PM
gbvette62's Avatar
gbvette62
All 73-75 Corvettes came with a cowl induction, fresh air system. It consisted of a flap in the rear underside of the hood, that opened under certain load conditions, and an air cleaner with a rubber seal, similar to the 70-72 Chevelle units.
A 73-75 assembly manual will show you all the parts involved, and a 73-75 Corvette Shop Manual has info on how it operates.
Old Oct 17, 2011 | 02:47 PM
Mike Ward's Avatar
Mike Ward
The flapper opens via a solenoid activated by an electrical switch under the gas pedal linkage when the pedal is floored. All show, (some noise) but no 'go'.
Old Oct 17, 2011 | 02:53 PM
Ganey's Avatar
Ganey
Some remove the flapper under hood so it's always open.
There is a 73 website: http://www.73spot.com/
To cowl induction
