Header Opinions
Old Oct 21, 2011 | 01:03 AM
hobby28's Avatar
hobby28
6th Gear
Default Header Opinions
I am building a 406 for my 74 vette and i would like to run 1 3\4 headers. What is the best brand to run for the money. I will be using afr 195 cc eliminators for cylinder heads.
Old Oct 21, 2011 | 02:55 AM
cv67's Avatar
cv67
St. Jude Donor '05
Check and see what Summit, maybe Hedman have.
Dougs makes a high quality piece dont know if they are avail. for the C3.
Old Oct 21, 2011 | 03:52 AM
hobby28's Avatar
hobby28
6th Gear
Should i just stick with 1 5/8 headers instead or are the 1 3/4 headers really worth the extra money in horsepower?
Old Oct 21, 2011 | 12:24 PM
DRIVESHAFT's Avatar
DRIVESHAFT
It depends on the kind of hp you expect to make.
For a 500+ hp engine I would spring for the 1 3/4" headers.
If this will be a 400 hp daily driver, buy the little ones.
Old Oct 21, 2011 | 01:04 PM
Les's Avatar
Les
On a 406, if you're springing for heads that can flow like the AFR Eliminators, I'd definitely go with 1 3/4". I run Hedmans on the smallblock in the Z28 in my avatar and have been very happy w/ them.
Old Oct 21, 2011 | 04:30 PM
C3 Stroker's Avatar
C3 Stroker
For a small block, your only choice for 1 3/4" headers are Hooker Super Comps. No one else makes this size for C3's. Not cheap, but they are an excellent choice. I have these on my 427 small block, and also on my former 383 with AFR 195's.
Old Oct 21, 2011 | 05:17 PM
Tim H's Avatar
Tim H
How is the fit situation with 1 3/4s??
Because the 1 5/8s will almost put themselves on for you.
Old Oct 21, 2011 | 08:00 PM
C3 Stroker's Avatar
C3 Stroker
Depends on your heads (angle plugs, stock, etc.), but mine went on almost by themselves with the AFR 210 Eliminators....easy fit, good spark plug access.
Old Oct 21, 2011 | 08:12 PM
Ganey's Avatar
Ganey
Things may have changed, see this topic
http://forums.corvetteforum.com/1574392555-post11.html
Old Oct 21, 2011 | 08:33 PM
hobby28's Avatar
hobby28
6th Gear
I haven't purchased the afr eliminators yet should i get angle plug or straight plug for header clearance?
Old Oct 21, 2011 | 10:10 PM
Les's Avatar
Les
If Hooker is your only option, as mentioned above by C3 Stroker, you should talk to both them and AFR to see what they have to say. There's another header maker that may make a 1 3/4" header for you- at least they show it in their catalog. Here's a link-
http://www.originalheaders.com/catalog.htm
To Header Opinions
