78 interior leak
Old Oct 21, 2011 | 01:58 PM
jdeel92's Avatar
jdeel92
Default 78 interior leak
okay so this thing has me bum fuzzled
it will rain
next day go to the vette
EVERYTHING! is totally dry except for passenger floor board?
seats are dry and everything just the floor baord
you guys have any suggestions?
thanks
Old Oct 21, 2011 | 08:47 PM
7t9l82's Avatar
7t9l82
it is likely the windshield frame. pull the kick panel and check there run some water on the windshield frame at the same time
Old Oct 22, 2011 | 08:31 AM
chucks's Avatar
chucks
C3 of Year Finalist (stock) 2019
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
Likely "A" pillar rust
Old Oct 22, 2011 | 09:27 AM
gbvette62's Avatar
gbvette62
This is real common.
Water gets in the windshield frame in the header area, and runs down the "A" pillars and on to your floors. GM filled the area in the header, where the outer windshield molding and the T-top molding meet a with sealer like what use to be called "dum-dum". If you look at an AIM, you will see that the installation of this sealer was somewhat haphazard, and over time, it dries out and shrinks up, allowing water in between the moldings.
Many a 68-82 Corvette has been found with a rusted out windshield header, "A" pillars, cowl and/or floors, because of water getting in through this area.
To 78 interior leak
