I have a 76 with an 80 style fiberglass bumper with the bubble tail lights. They were on there when I bought the car so I don't know much about how they are installed. Here are a couple pics.
The 74 up Corvettes need the adapter ring, because the tail lamps used in those years was a complete assembly, with the lens and housing assembled as a single piece. The 68-73 tail lamps were 2 piece, with a metal housing attached to the body, and the lens held to the housing by screws.
Without the adapter ring, there is no way to hold the lamp socket, or to attach the lens to the bumper.
I have the bubble conversion kit in my 80. It's essentially bolt in. Bubble light assemblies mount exactly as the stock units. You will remove the backup lamps and tape the pigtails to the wiring harness. You can cut these if you want, but leaving them allows you the opportunity to convert back to stock at a future date.
The kit comes with two pigtails/sockets to scotch lock to the outer tail light harness. Add the lamps, plug them up, and you're done.
You will not have backup lights but, to be honest, how often to you actually need backup lights?
They make kits to mod tail light lens for 68-73 direct replacement.
And 75-82 includes lens and adapter housings.
Anybody have a picture of this adapter housing, would like to convert to the bubble lens?
How about some close up pics of bubble lens on a 74-75.
I don't want to go the digital light route.
I have a new unused set I bought for my 75 that I am not going to use.
I changed my plans to the 80 style rear look and diode lights.
If you are interested in buying them for less than what they sell for now, drop me a PM.
Installing bubble light taillight kit to 76 corvette with the upgrade bumper. I understand how to do it but..... the outside lights are fine, the inside lights, because of the backup light have the hole higher up in the bumper where the bulb assembly goes in. Do I have to cut a bigger whole in there to make them fit straight? Don't really want to cut the bumper if I don't have to.
Anyone know?
Thanks Peggy
Peggy- Yep, you have to cut the back body panel for the bubble lights to fit the in the backup light holes. Not a problem with fiberglass. I figure my 75 is never going to be a collector car and right now it's mine anyhow. Got out the keyhole saw and drill and went after it.
I really like bubble lights!
Good luck.
Roy
Once a year, when you go have it inspected, at least in my state. Actually, back-up lights are nice to have if you ever back up at night. Also, they are useful in parking lots, if you see the back-up lights, you know that a car may be backing out of a parking space. Back-up lights are there for a reason, just like turn signals. Hmmmm, maybe I shouldn't have brought up turn signals, I'm from Massachusetts, where using your turn signal is considered a sign of weakness.
