PS Control Valve Rebuild....leaking
Old Oct 21, 2011 | 09:59 PM
LannyL81's Avatar
LannyL81
Default PS Control Valve Rebuild....leaking
My first attempt at rebuilding the PS control valve, I tore the lip seal.
So tried again and took alot of care and was sure that I did not tear it this time...everything went back together just fine.
Now it is leaking out the dust cap....
I followed the instructions and pictures.....is there something not in there that I did wrong??
Can't wait to take everything apart again...NOT
Old Oct 22, 2011 | 12:01 AM
Drawmain's Avatar
Drawmain
Leaking out the dust cap leads me to one of the o rings or a damaged piston in the body of the valve.
Old Oct 22, 2011 | 10:09 AM
LannyL81's Avatar
LannyL81
When I installed the Or rings, I made sure they were not twisted..but???
The piston looked fine...so did the bore...but again???
I just got another seal kit and will replace everything....again...
I used the instructions from CSSBINC.COM.
Old Oct 22, 2011 | 11:09 AM
69 Chevy's Avatar
69 Chevy
Continually leaking PS parts finally led me to scrap that OEM setup and install the Steeroids power R&P. I'm glad I did.
Old Oct 22, 2011 | 01:13 PM
Drawmain's Avatar
Drawmain
There may be enough wear on the bore of the valve to allow fluid to leak past. I will most likely end up replacing my stock system in favor of a rack system or the Borgeson system soon. Have to build up funds first
Old Oct 23, 2011 | 11:01 AM
LannyL81's Avatar
LannyL81
Yep....installing the Steeroid system would sure take care of the leaking problem....but a new valve is alot cheaper....not as nice though. I just had the steering box rebuilt so I will not be going that route.
Thanks to all.
Old Oct 24, 2011 | 06:17 PM
LannyL81's Avatar
LannyL81
I re-read the rebuild instructions and on one page it states to push the piston out in this direction only.....the other direction has a 97% chance of damaging the piston/bore.
Soooo.....I am thinking that I probably removed the piston out the wrong end and damaged something...hence why it is leaking out the dust cap.
Anyone know exactly why damage occurs if piston is removed in this direction as opposed to the other direction?
Anyone have any experience with the rebuilt control valves available....or is it best to just get a new one?
Old Oct 24, 2011 | 07:02 PM
boltnut's Avatar
boltnut
Anyone know exactly why damage occurs?
I just bought one off eBay....I'll let you know when it gets here....
To PS Control Valve Rebuild....leaking
