oil pan RnR
Old Oct 23, 2011 | 01:57 PM
boltnut's Avatar
boltnut
Default oil pan RnR
will removing the power steering pump cylinder thingy be enough to get the pan off or do i need to remove the centerlink too ?
Old Oct 23, 2011 | 02:50 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
It HELPS to remove the power steering shaft from the frame bracket, it's just one more nut.
It's NECESSARY to drop the center link. I think the easiest way is to unbolt the idler arm from the frame.
Old Oct 24, 2011 | 12:15 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Pretty much what Kaps said. U may want to drop the starter too. That gives u much more access when it is time to clean and replace the pan gasket.
cardo0
To oil pan RnR
