Rear suspension ????????
Old May 5, 2002 | 01:33 AM
theandies's Avatar
theandies
Default Rear suspension ????????
My rear tires are cambered in at the top a little (I know this is common with Corvette rear suspension) but I think it is a little excessive. I know my rear suspensions bushing need to be changed (actually it needs a complete rebuild someday soon) but I want to take some of the camber out. I've checked all my books for dimensions and how to do it, I want to ask the people who have done it and get the tricks a secrets from the best group of Corvette people on the planet. smooch smooch :lol: . Please give me some insite and wisdom. My suspension is completely stock so I am stuck with the cam bolt for adjustments.
John
Old May 5, 2002 | 01:52 AM
EarnIt's Avatar
EarnIt
Default Re: Rear suspension ???????? (theandies)
There is a procedure on this at: corvettefaq.com
Old May 5, 2002 | 02:28 AM
theandies's Avatar
theandies
Default Re: Rear suspension ???????? (EarnIt)
Bad Link
John
Old May 5, 2002 | 03:31 AM
Brutus's Avatar
Brutus
www.corvettefaq.com
Old May 5, 2002 | 03:32 AM
1979toy's Avatar
1979toy
The link should be http://www.bokonon.net/corvettefaq/
No big challange to adjust the camber. Just do not expect to get it right the first time. It will help if you have a bubble level, as is used in building houses, and a piece of wood that you can cut to length to fit flush to your rim. You will have to drive the car a bit between adjustments to level the suspension out.
Old May 5, 2002 | 10:18 AM
theandies's Avatar
theandies
Default Re: Rear suspension ???????? (1979toy)
Thanks, and I like this part :yesnod: :yesnod: :yesnod:
John
Old May 6, 2002 | 01:47 PM
theandies's Avatar
theandies
Anyone else have suggestions, experiences they would like to share with me?
John
Old May 6, 2002 | 01:54 PM
FeedVaal's Avatar
FeedVaal
With the adjustable cam is very hard to keep a good camber once it is set. I went to the adjustable strut rods and am very happy. Best mod you can do IMO.
Old May 6, 2002 | 02:29 PM
Koz
Guest
Posts: n/a
Not really... but I would like to know how you make out! I have a bubble level but that's about it.
I couldn't find the write-up.. Anyone have a specific URL they could post.. :cheers:
OK.. I found it.. Does anyone have any pictures of this home made tool?
[Modified by Koz, 1:39 PM 5/6/2002]
[Modified by Koz, 1:55 PM 5/6/2002]
Old May 6, 2002 | 02:44 PM
Alwyn678's Avatar
Alwyn678
Default Re: Rear suspension ???????? (FeedVaal)
Where did You get adjustable Strut Rods??
Old May 6, 2002 | 02:45 PM
flynhi's Avatar
flynhi
Phase one - adjust camber as below.
Phase tWo - get VB adjustable strut rods and readjust.
Phase three - get VB smart strut bracket and readjust.
Old May 6, 2002 | 02:53 PM
vicrattlehead's Avatar
vicrattlehead
Default Re: Rear suspension ???????? (Alwyn678)
I have seen three types of adjustable strut rods available in the Mid-America Designs catalog. They have the stock non-adjustable rod version (adjustments made with stock-type cam system), an adjustable rod with urethane bushings version, and the heavy duty adjustable rod with ball type heim joints version. They are priced at about $100, $130, and $180 respectively. The adjustable rod versions do away with the cam system and instead rely upon turning the rod with a wrench for positive/negative camber adjustments. I'm thinkig about getting the heim joint versions later this summer. Mid America Designs Site----www.madvet.com
Old May 6, 2002 | 09:50 PM
theandies's Avatar
theandies
Default Re: Rear suspension ???????? (vicrattlehead)
I am getting the adjustable rods when I do my complete rebuild in the future but what I am looking for in this post is do you jack the car up and then jack the spring? Do you do it on the ground? See where I am asking. I guess I should have ask these question in the original post..sorry guys/gals.
Thanks for all the responces to date and please keep'em coming.
John
Old May 6, 2002 | 11:33 PM
FeedVaal's Avatar
FeedVaal
To adjust the stock cams, it's helpfull to have weight off but maintain ride height. So with weight on car, measure distance between trailing arm and frame and insert a shim between those two points before jacking.
I've used 1/2 drive sockets and gotten close but you may have to make something.
Old May 7, 2002 | 01:30 AM
theandies's Avatar
theandies
Ahh, then jack that side of the spring up until the trailing arm "wedges" the shim between it and the frame? I think I am getting you.
John
[Modified by theandies, 11:30 PM 5/6/2002]
Old May 7, 2002 | 11:51 AM
theandies's Avatar
theandies
TTT
To Rear suspension ????????
