From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Auto-4speed conversion & U joints..80 model
Have read , and can not find an article about the difference between an automatic driveshaft vs. a 4 speed driveshaft (80 model) and their respective U joints. I am assuming they are different sized .
So I am currently acquiring parts for an 80 model automatic to 4 speed conversion. Super T10 trans, yoke and driveshaft are in my shop...
Seem to remember that a special U joint can be purchased for the rear whereas one side is sized for the driveshaft, the other side is sized for the rearend coupler. Thats right, a U joint with 2 different size cups...
Anyone know? (maybe I dreamed this?)
The driveshaft currently in the car is an automatic one, the 4 speed driveshaft has this numbered tag attached:
14014606XD
Do you have the 80 assembly instruction manual (AIM)? If the driveshafts are different, the AIM will list two different part numbers.
I have the AIM Big Mike, and will look after I get thru with this grade 8 bolt cutting project. Cutting 2 inch down to 1 3/4 in. bolts with a cutoff wheel. Yes, that 1/4 inch makes a difference when coupling the trans to the bell
Thought I could draw from someones experience ? thanks for anyone's response.
Y E P !
I think thats what I need..... 1310 to 1330 .... will not know for sure till I start the project, but this smells like the one.
Anyone have more / better/ accurate info? Please and Thank You .
Originally Posted by commander_47
The AIM won't really help here. The auto tranny has a smaller diameter U joint than the manual.
To use the auto driveshaft with a super T10, like I am, you have to get the universal from summit racing.
That is the part number needed. I'll stop by and try to get it today and post.
But I bought a 4 speed driveshaft, with the T10 trans. I will be using my existing rearend, just everything in front will be a 4 speed system. Also have the 4 speed trans yoke.
So, will I need said U joint for the rearend yoke?
There conversion joints, and the one you may require would be a 1270-1310, my books are not with me...however I think its correct ..we sold several for diifferent applications and I know there out there...the number above is one of the most popular and can be interchanged if you find a smart counterman....
Here are some part numbers for the conversion U Joint you are looking for (1310/1330):
Precision Super Joint #253 (Summit Racing PCN-253)
Brute Force #1-0134BF
Neapco #1-0134
Performance Dynamics Dura-Lubed #2-0344
Spicer #5-134X
You are correct that you will need a conversion U joint. The 1980 diff driveshaft yoke is a 1310. Both automatic and manual transmission cars came with the same size diff yoke. The transmission yoke for the manual equipped cars had the bigger 1330 U joint.
You can verify that the 4-speed driveshaft has 1330 U joints by measuring the end cap distance (end to end). It should be 3.6250" (3 5/8"). If it was a 1310 U joint then the end cap distance would be 3.2190" (3 7/32").
Just measured the U joints on the driveshaft that was sent to me as a 4 speed shaft. I have no reason to believe that it is not what the seller claims. And by your posting above, it seems to verify that as well.
My 4 speed shaft has 1 1310 U joint on one end, the other end has a 1330 joint... I am assuming that the differential yoke is a 1310 ( 3 7/32 inch end cap -end cap) by reading your above information. I am not by my car to measure the existing diff. yoke.
If that is correct, then I will only need 1-1310 joint and 1-1330 joint....And will not need the special "conversion" joint.
Is that what you get ?
Thanks.
I used a take apart yoke at the trans on my DN 5 speed conversion. I then had the local driveline should but a new flange on the trans end of the drive shaft. This way I can get common joints if it fails on the road.
