Engine Wizards...advice needed!
Old Oct 27, 2011 | 03:21 PM
jlhtec's Avatar
jlhtec
Default Engine Wizards...advice needed!
Ready to upgrade the existing top end, and have been thoroughly reading the forums.
My Possible top end changes on stock 1981 bottom end:
*Vortec heads - mildly ported/stock valves/milled to 60cc. Already have ready for the machine shop.
*1.5 or 1.6 stamped roller rockers
*Lunati 60103 or xe268 kit -k12-242-2
*Edelbrock Vortec air gap intake
*Not sure on Head Gasket thickness
*Would like to stay on 92-93 octane if possible.
I know there are some mods to the heads to get them to work with the cam. I will probably let the machine shop lower the guides during the valve job.
I plan to stay with stock converter until my 200r4 swap mid next year.
Any advice on chosen components, or things to watch out for, would really be appreciated.
Thanks,
Jeff
Old Oct 27, 2011 | 04:34 PM
johnt365's Avatar
johnt365
Jeff, I just installed the xe268h and I love it. However, I will tell you that it really pushed against the stock converter on my th400. (I plan on the 2004r upgrade as well down the line)
I bit the bullet and put a 2800 converter in and it was great. But my rear gears were 3.08 and it was still a dog. Changed to 3.55 and the cam works real well and a 2004r will be better.
The cam sounds great to me too with a noticeable lopey idle.
What I am saying is that you will love the proposed changes to a stock set up. However, not matching the converter and rear end may keep you from realizing the power. What are your rear gears?
Old Oct 27, 2011 | 09:08 PM
billla's Avatar
billla
St. Jude Donor '14
Vortecs are a great pick - make sure the porter knows what they're doing - it doesn't take much on the Vortecs and 90% of the work should be on the exhaust port. Why are you milling them to a 60cc chamber? Honestly...I would install the Vortecs untouched. I don't see the value in higher lift with the Vortecs given the flow numbers - but you're better off buying upgraded Vortecs from Scoggins-Dickey or another source vs. paying someone to do it.
Might as well do 1.6 rockers and have the shop drill out the pushrod holes as required. Keep in mind the Vortecs require self-aligning rockers. This will affect your cam choice for sure.
You'll know the required head gasket thickness once the heads are off and you have the deck height.
Premium unleaded is good to about 10.2 with ideal quench.
Old Oct 28, 2011 | 10:55 AM
jlhtec's Avatar
jlhtec
Thanks for the comments!!
John: I was expecting exactly what you experienced with the setup.
Billa: 60cc should get me 9.5 -10.2CR depending on gasket and deck height. I think. As you mentioned, I won't know until I pull the old heads.
I paid $100 for the heads, prior to knowing much about Scoggins-Dickey.
I am only cleaning up the intake ports. Removing the ski jump on the exhaust and clean up.
I'm expecting $220 for Valve job, $30 for Junk yard valave covers and stock rockers. That is until I get some 1.6 rockers.
Old Oct 28, 2011 | 11:45 AM
pawpaws toy's Avatar
pawpaws toy
Which air gap manifold will you use? I don't think the RPM air gap will fit under a stock 81 hood.
Old Oct 28, 2011 | 11:47 AM
MakoShark72's Avatar
MakoShark72
According to the Air Gap paperwork, it will not...
Old Oct 28, 2011 | 12:17 PM
BKbroiler's Avatar
BKbroiler
I have a Vortec type RPM Air Gap manifold under the stock hood on my 77. It fits with a drop base air cleaner, not with a stock air cleaner. One thing to keep in mind is that the RPM Air Gap for Vortec heads is a square bore carb type only. I'm using a 3/4 inch thick adapter on mine to work with a Qjet carb. Even that fits under the hood, but it is very close. I can't use a wing nut on the air cleaner because it hits the hood.
Old Oct 28, 2011 | 02:06 PM
jlhtec's Avatar
jlhtec
Thanks Again!!
I'm pretty confident a RPM air gap will fit under the hood. Current is stock GMCFM with 3/4" squarbore adapter + Edelbrock 1406 + drop base air cleaner. Still quite a bit of room to the bottom of the hood.
Old Oct 28, 2011 | 04:08 PM
HBZ_81_C3's Avatar
HBZ_81_C3
RPM Air Gap WILL fit under a '81 hood with a drop base air filter.
Old Oct 28, 2011 | 04:40 PM
scottyp99's Avatar
scottyp99
The '80-'82 hoods are pretty low, (part of what I like about 'em, looks-wise) I don't know how much lower than a '77, although HBZ_81_C3 says it'll work. I have a 1980 with a plain Performer intake with a Holley 600, dropped base air cleaner with a 3" element, and it's a pretty close call, just about an inch if I used a hex nut instead of a wing nut. If you can find the difference in height between a Performer and an RPM Air Gap, that might tell you something. A couple things to keep in mind here, are that you need the top of the air cleaner to be a good inch away from the top of the bowl vents, maybe you could squeeze it down to 3/4 of an inch if ya needed to, but that's cutting it pretty close, the more room the better, and the air cleaner element is another case of the more the better, any less than 3" and you're getting iffy.
You can pretty much stick whatever you want, within reason, under an L88 style hood, just something to think about.
Scott
Old Oct 28, 2011 | 05:07 PM
billla's Avatar
billla
St. Jude Donor '14
Anything less than a 3" element has real impact on power output.
Old Oct 28, 2011 | 11:45 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Factory Vortec heads are only good for 0.450" lift so check to see you have adequate clearance. To gain more room for additional lift you need to add +.050" keepers and/or replace the stock positive seals with umbrella seals and/or machine the guides down for additional clearance.
To Engine Wizards...advice needed!
