1978 rear wheel bearings
Old Nov 1, 2011 | 04:48 PM
bmprhmpr's Avatar
bmprhmpr
Default 1978 rear wheel bearings
On my 78 the bearings(rear) slipped off the spindle. Im doing a frame off on this car. Car sat for almost 20 yrs. has 57k miles. Before takeing spindle/hub apart there was no problem, no play or ruff spinning. Brgs. race, and spindel look good no pitting or discoloration. I thought the brgs were a press fit or are 1978s a slip fit? Any imput?
Old Nov 1, 2011 | 04:56 PM
drwet's Avatar
drwet
They are a press fit. If the bearing came off the spindle, you've got major problems. I would recommend sending them off to someone who is experienced in rebuilding Corvette trailing arms and have the entire assembly rebuilt. Might as well do the other side while you're at it. Van Steel is a good choice.
Old Nov 1, 2011 | 08:48 PM
birdsmith's Avatar
birdsmith
Not sure what the exact diameter of those spindles is supposed to be but it sounds like yours has somehow worn undersize, which would likely necessitate replacement. Perhaps Van Steel, et al could chime in with that info so you could measure it/them...
Old Nov 1, 2011 | 10:05 PM
Duane4238's Avatar
Duane4238
Or maybe someone replaced the spindle with a slip fit replacement as was common some years back. There was just a thread about this a month or so ago.
Duane
Old Nov 2, 2011 | 12:41 PM
Rally68's Avatar
Rally68
Duane
Lot of people do this & have put on many miles...
Old Nov 2, 2011 | 04:43 PM
7t9l82's Avatar
7t9l82
used to be very common.
Old Nov 2, 2011 | 05:19 PM
63split63's Avatar
63split63
Lots of people still do this . You can service the bearings easily without pounding the s*** out of everything instead of waiting for them to fail and then fixing the mess .
JMO Bill
Old Nov 3, 2011 | 10:24 AM
Kevin79's Avatar
Kevin79
Is there a thread with info about how to check the beatings? I have a 79 and have a growl noise from the rear end that happens more on decell. I don't want to break into the rear end if I don't need to.
Old Nov 3, 2011 | 12:08 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
IF you rear is making noise, have to break into it. Also my motto when it comes to slip fit bearings is if they slipped on, they can slip off too. Look up forum member tracdogg2. he builds rear ends and trailing arms better than anyone.
Old Nov 3, 2011 | 05:39 PM
Kevin79's Avatar
Kevin79
Thanks for the info
Old Nov 3, 2011 | 06:01 PM
lionelhutz's Avatar
lionelhutz
The bearings should be a press fit.
Arguing that "a slip fit works for the front spindles so it'll work for the rear spindles just as well" is just plain wrong. Think about this. Stand a roll of electrical tape on it's edge. Stick a pen or other suitable round object through the middle. Roll the pen against the bottom of the tape so it moves the tape back and forth. See how the pen rolls along inside the roll of tape as both are rotating. The same type of thing will happen with a slip fit. You need an interference fit so the spindle and bearing race don't move against each other.
It works for the front because the spindle and bearing don't rotate. The outer race is the one that rotates with the hub and it's a press fit.
Since you're doing a restore you'll have to knock it all apart anyways so you can take a closer look then. If new bearings aren't a pressed fit then it's time to replace the spindle.
Peter
To 1978 rear wheel bearings
