Rear End Question
Old Nov 2, 2011 | 02:46 PM
AP4EVER's Avatar
AP4EVER
Default Rear End Question
I haven't had my 81 vette for long and was looking at different thing on the rear end and realized that the driver side strut rod is bent. With this being bent should there be other areas that I should be concerned with? How do you know if the rear spring needs replacing?
http://members.toast.net/akfoy/photos//S5002744.JPG
http://members.toast.net/akfoy/photos//S5002745.JPG
I was considering on doing a read rebuild kit like this from Willcox. Should this take care of everything?
http://willcoxcorvette.com/product_i...ducts_id=25238
Old Nov 2, 2011 | 02:59 PM
wombvette's Avatar
wombvette
Common alignment technique at Bubba`s Alignment shop.
Old Nov 2, 2011 | 03:28 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you had the rear alignment checked? A bent strut rod is not particularly good, but no harm done if it is not affecting the alignment.
Do you have a fiberglass rear spring? They don't wear out.
Old Nov 3, 2011 | 07:39 AM
AP4EVER's Avatar
AP4EVER
Have not had the rear alignment check. Was going to wait till after I have replaced the bushings
Old Nov 3, 2011 | 08:57 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Very common fix buy "bubba's" have a look at othe components, fiber glass springs are usually pretty dependable , make sure there are no cracks in the spring, should be OK
To Rear End Question
