75-79 Tail lights on an a 81?
Old Nov 3, 2011 | 11:01 AM
mightygeorge's Avatar
mightygeorge
Default 75-79 Tail lights on an a 81?
Hi all,
first post here - hope I'm asking at the right place. I have an 81 that was imported in the UK with the bubble light conversion. It's all red lenses which is illegal here for the year (need amber rear indicators).
I need to replace them at some point but I am not a big fan of the 80-82 tail lamps. They look a bit... 80s!
Other than correctness (for which I don't particularly care) do you know if it is possible to fit the lenses from a 75-79 on an early 80s car? Has anyone tried it and if so, are there lots of mods needed?
Many thanks in advance,
George
Old Nov 3, 2011 | 11:34 AM
Ganey's Avatar
Ganey
Welcome.
Since the bubble kit is listed for 75-82, should be easy. You would still need amber rear indicators as 75-79 are red here.
Old Nov 3, 2011 | 12:39 PM
mightygeorge
Originally Posted by Ganey
Welcome.
Thank you! Interesting point about the bubble kit!
The conversion that I was thinking of and is commonly done across the pond is to use amber bulbs for the clear reversing lens and change the wiring around. It's a bit of a pain but it makes it legal.
So... has anyone done it? Any photos by any chance? Thanks again!
Old Nov 3, 2011 | 12:40 PM
SteveG75's Avatar
SteveG75
'75-79 are all red. Two outer are brake/turn signals plus running lights. Inner are reverse lights. Trouble will be wiring up separate turn indicators since the wiring is shared with the brake lights.
Old Nov 3, 2011 | 12:55 PM
Ganey's Avatar
Ganey
I considered you might have found amber for 75-79.
Mid America shows amber lights in this pic. for louvers, not ambers.
http://www.mamotorworks.com/corvette...1-42-1280.html
Wiring w/ amber bulbs is clever.
It should be possible to dye the clear part amber. If you cannot get orange there you might try a WTB in parts.
I run 4 stock 77 tail lights so I did some wiring.
Old Nov 3, 2011 | 12:56 PM
mightygeorge
There is a wiring 'how to' guide here if anyone else ever needs to do it (courtesy of the CCUK website).
http://www.corvetteclub.org.uk/files..._mod_guide.pdf
I was just wondering whether the lenses from a 75-79 will physically fit or if they were different sizes, but I think they should be ok!
Old Nov 3, 2011 | 01:24 PM
Ganey's Avatar
Ganey
Some put 80-82 rear bumpers on 75-79 so they would probably use 75-79 lights...
This shows 75-79 lights in red & black cars. What color is yours & did you see my previous post?
http://forums.corvetteforum.com/c3-g...per-cover.html
Old Nov 3, 2011 | 03:34 PM
mightygeorge
Just seen it - thanks. I think we were posting at the same time!
Mine is red but I think from decoding the trim tag a little while back it was originally black and silver.
Clearly there are cars with the 80s bumper and the late 70s tail lights so it must be possible! I think it's a much better classic look than 80-82 lights but each to their own! Many thanks guys!!!
mightygeorge
To 75-79 Tail lights on an a 81?
