1968 L79 clutch replacement
Old Nov 4, 2011 | 12:36 PM
Backfire41's Avatar
Backfire41
Cruising
Default 1968 L79 clutch replacement
In looking under the car the crossmember for the transmission is not removeable as it is welded to the frame. Does this mean pulling the engine to replace the clutch?
Old Nov 4, 2011 | 12:53 PM
dntoearthman's Avatar
dntoearthman
no you don't have to pull motor the tranny will slide out. if you put a richmand 5spd in like I did you have to pull the engine.
Old Nov 4, 2011 | 01:00 PM
Backfire41's Avatar
Backfire41
Cruising
Thanks.
To 1968 L79 clutch replacement
