battery drain 79 vette
Old Nov 5, 2011 | 06:50 PM
79c3man's Avatar
79c3man
Default battery drain 79 vette
brand new optima battery goes dead if i don't drive the vette for 2 days ,found procedure for battery drian on internet I put test light between neg battery terminal and neg battery cable light is bright with door open then dim when shut ,I pull courtesy fuse and light goes away ,what are all the things on that fuse this is so aggrevating any suggestions
Old Nov 5, 2011 | 07:15 PM
SIXFOOTER's Avatar
SIXFOOTER
This is for an 81 but it should be pretty close for a 79
Old Nov 5, 2011 | 07:51 PM
Peterbuilt's Avatar
Peterbuilt
First thing you might check is the "Interior light delay timer", remove that from the circuit and see it thats the problem.
Old Nov 6, 2011 | 01:34 PM
79c3man's Avatar
79c3man
Default i think i found it
I know where the battery drain is but don't know what it is ,there is a relay located under the shifter handle driver side of console 5 wires going to it light blue ,dark blue ,yellow ,orange ,black ,anybody know what this is for ,79 corvette
Old Nov 6, 2011 | 02:13 PM
BHRIG's Avatar
BHRIG
Your alarm.........?
Your alarm could be on with the horn in left rear wheel well bad and not sounding.....just a might be!!!
good luck
Old Nov 6, 2011 | 08:24 PM
kydirt's Avatar
kydirt
My 79 also had a drain on battery. I removed all the alarm wires and it will sit all winter and still start. I believe it was the wires you are talking about.
Old Nov 8, 2011 | 12:08 AM
Steve COSD's Avatar
Steve COSD
I had this a few years back. Turned out to be a bad alternator.
To battery drain 79 vette
