Horn not working....help
Old Nov 9, 2011 | 09:48 AM
larrym59's Avatar
larrym59
4th Gear
Default Horn not working....help
I just purchased a 1979 C3 and replaced the main instrument wiring harness...the guy who had the car before me had really screwed with the wiring behind the dash.
After I installed the new harness the horn will not work.
When I plug in the horn relay it energizes and I get sparks and plunger in the steering column gets hot. I can unplug the horns and the relay does not energize and I have twelve volts on the wire going to the horns. I can unplug the harness from the steering column and the relay energizes.
I know this is a simple system..3 wires and a relay...but this thing has got me baffled.....any help would be appreciated.....
Old Nov 9, 2011 | 02:19 PM
larrym59's Avatar
larrym59
4th Gear
Forgot to add that when I jump the green wire to the orange wire on the relay connector the horn honks.....Dam I have rewired a 55 ford street rod truck and didnt have this much trouble.......
Old Nov 9, 2011 | 03:00 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Some Vedors ( I wouldn't buy from Corvette Central, seems most of the pars are coming back with a 1 inch or so tolerance and their customer service reps are trained on how not to replace or refund their products made in Guangdong)
But Wilcox have a complete kit. I just did mine and very easy to do. Take the honker off and see what is not making contact and order their kit of just the piece you need. Wicox is a good company to deal with and you can actully talk to somone there,
instead of "Sorry Charlie your 30 min or 30 mile warranty is gone, buy another one from us whats $100 to you guys that drive Vettes.
What happen if you are doing a frame off and the parts aren't installed in 30 days
Kinda funny because I was late one night and did a second gear burnout in front of a restaurant ( totally my mistake ) that all the kid with their fart cam mufflers to make them feel more macho and brought a mass of patrol cars out to harass me. There were 6 patrol cars there 4 from local police and 2 from Enviromet Canada wasting am hour on a 50 year old guy with his price and joy out for a spin.
My horn didn't work, there was one fine, he said "does the parking brake work" and I told him yes it does. The Vette was not running by then and I pulled the emergency and the red brake light went on at the dash.
Him being a ***** and not knowing my car yet went around the back. Before he got there I pressed the brakes on hard and then he tried to push it, needless to say it didn't didn't move so i got out of another fine. Matter of fact I ditched the actual cable itself.
Old Nov 9, 2011 | 03:55 PM
larrym59's Avatar
larrym59
4th Gear
Default Got it fixed
I finally figured out the problem with the horn.....new wiring harness from mamotors.com had the black wire and the green wire, wired into the connector backwards, who would have thought a new harness would have the wires backwards in the connector.
I found this by removing the original connector from the the old wiring harness and using jumpers checked to make sure everything worked as it should. then checking the old connector to the new connector found the wires were installed wrong....just a thought...when you get a new wiring harness check all your connectors to the new harness and make sure they have wired everything correctly.........see you when I have another problem, or when I get the car finished and post pics.
To Horn not working....help
