New 454 engine swap
Old Nov 9, 2011 | 09:20 PM
dduenkel's Avatar
dduenkel
Default New 454 engine swap
Well I pulled the trigger on a new ZZ454 engine and a TKO 600, I thought I would show my new engine and the process as it goes in. I hope to have it all complete by Thanksgiving! It is going into a 1971 Convertible.
Old Nov 9, 2011 | 09:51 PM
iokepakai's Avatar
iokepakai
DAT'S BEAUTIFUL! Keep us posted on the install....May thinks go smoothly....Aloha's
Old Nov 9, 2011 | 11:03 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
All I can say is make sure that you keep a few bucks lying around for new tires.
Looks great.
Old Nov 10, 2011 | 12:54 AM
TNX ZORA's Avatar
TNX ZORA
Are you planning to use the carb and air cleaner the engine came with and if so have you been able to determine if they will fit OK under the hood?
Old Nov 10, 2011 | 09:06 AM
Sully1882's Avatar
Sully1882
sweet! I am jealous!
Sully
Old Nov 10, 2011 | 01:23 PM
dduenkel's Avatar
dduenkel
Yes I have a hi rise hood so they will fit under it. If it was not the hi rise hood this setup wouldn't work. It is a Holley 770 Carb that came with the engine. This crate engine was an entire setup even the plug wires were run when I pulled it from the crate.
Old Nov 10, 2011 | 03:40 PM
lumij3's Avatar
lumij3
Are you planning to redo all the electrical in the car also? Why did not you go fuel injection? Just cuirious, I am trying to decide what to do in my 69 rebuild that I am about to start soon.
Old Nov 10, 2011 | 04:16 PM
TERRY CLARK's Avatar
TERRY CLARK
Is Envy still a deadly sin ?
Old Nov 10, 2011 | 06:05 PM
DAVID SLUDER's Avatar
DAVID SLUDER
Awesome, I am thinking about the same set up for my 69, so keep us posted and lots of pics, good luck
Old Nov 10, 2011 | 06:07 PM
DAVID SLUDER
What is the part # of the engine and where did you get it?
Old Nov 10, 2011 | 06:31 PM
Rebelrob's Avatar
Rebelrob
I like it. I sure do like that intake water neck also. Did that come with it? Part #? Seems to backwards, does not swivel, does it ; - )?
Old Nov 10, 2011 | 08:22 PM
dduenkel's Avatar
dduenkel
Here is where I got the engine...
http://paceperformance.com/i-5146255...ed-finish.html
I decided against fuel injection because this engine came as a complete set and I do like a carburetor...
The intake water neck does swivel, just loosen the bolt and it swivels into any position for your setup. By the looks I am very happy, I just ordered a Billet Aluminum pulley setup also so it should look really nice at the end. I will be pulling the old engine on Sat and setting up the new one that day so I will take more pics.
Old Nov 10, 2011 | 08:43 PM
Ironcross's Avatar
Ironcross
fine looking product, ....enjoy
but I think you will have to use your old OE short water pump as the one on the engine is a passenger car pump.....,
Old Nov 11, 2011 | 11:59 AM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Wow, that looks really nice with those valve covers too.
I would be really tempted to change the cam to something with at least 220* duration before installing the engine though.
Old Nov 13, 2011 | 08:21 AM
dduenkel's Avatar
dduenkel
Well I got the engine and transmission out yesterday.
And I started to replace all the fuel lines with braided steel hoses...
Going to clean up the engine bay this week and hopefully start to put the new engine in next weekend!
Old Nov 16, 2011 | 11:03 PM
dduenkel's Avatar
dduenkel
The engine is almost ready to go in, should hopefully have it running this weekend.
Old Nov 17, 2011 | 12:55 PM
scrappy76's Avatar
scrappy76
watching this
To New 454 engine swap
Old Nov 18, 2011 | 06:13 AM
KanuckZ06's Avatar
KanuckZ06
I installed the same combination into my 69 vert, it has been the best money invested so far!
My engine came from Apple Chev in York PA, I bought it while at Fall Carsile, I saved 3K from buying it in Canada.
From Gm they don't come with a carb,wires,fuel pump and distributor, at least when I bought it 4 years ago, I added a short GM aluminum water pump and fuel pump, and changed out the automatic transmission flex plate to a manual transmission flywheel.
I use a Center Force Dual Friction clutch assembley, excellant performance so far!
Just add some Hooker side pipes like I did.
From your pictures, the car looks great,is that a VPB steering rack-attack?
Old Nov 18, 2011 | 11:14 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
You are gonna LOVE it!!!!! I've got 3.73's in the back and it will rip the tires at will and cruise 70mph @ about 2100rpm's!!!!!
Old Nov 18, 2011 | 03:40 PM
dduenkel's Avatar
dduenkel
From Gm they don't come with a carb,wires,fuel pump and distributor, at least when I bought it 4 years ago, I added a short GM aluminum wateryes that pump and fuel pump, and changed out the automatic transmission flex plate to a manual transmission flywheel.
Yes that is a vbp rack-attack it is great! Hope to get this on the road this weekend and I can't wait to drive it!
